How to add a service using API Javascript
7582
11
05-09-2015 08:48 AM
SteveCline
I am using the "require" script to load layers into a map.  I am able to successfully use the "esri/layers/ArcGISDynamicMapServiceLayer" script to load tiled layers but I am wondering how to add these two layers:
Cline/Regions_w_Country_Labels (MapServer)
http://services3.arcgis.com/HVjI8GKrRtjcQ4Ry/arcgis/rest/services/Major_World_Cities/FeatureServer/0
Any guidance is greatly appreciated.
Steve
RobertScheitlin__GISP
Steve,
   Sorry there was an error in my code it should be
outFields: ["CITY_NAME"]
An array of Strings not a string containing an array.
Steve,
   Normally you would use ArcGISTiledMapServiceLayer for tiled/cached layers. Use ArcGISDynamicMapServiceLayer for map services that are not tiled and you want to display the whole mapservice using the symbology from ArcGIS Server and not needing the geometry to be available on the client side. Use FeatureLayer for individual layers of a map service like http://services3.arcgis.com/HVjI8GKrRtjcQ4Ry/arcgis/rest/services/Major_World_Cities/FeatureServer/0 . A FeatureLayer actually downloads the geomerty to the client.
SteveCline
Robert -
That worked to bring the layer into the map.  Is there a way to add the style created on ArcGIS.com?
Thanks for your help.
Steve
Steve,
  When I add http://services3.arcgis.com/HVjI8GKrRtjcQ4Ry/arcgis/rest/services/Major_World_Cities/FeatureServer/0  as a Feature layer it pulls the symbology in as well. Here is a simple sample:
<!DOCTYPE html>
<html>
  <head>
    <title>Feature Layer Only Map</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
    <style>
      html, body, #map {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
    </style>
    <script src="http://js.arcgis.com/3.13/"></script>
    <script>
      require([
        "dojo/dom-construct",
        "esri/map",
        "esri/layers/FeatureLayer",
        "esri/geometry/Extent",
        "esri/InfoTemplate",
        "dojo/domReady!"
      ], function(
          domConstruct,
          Map,
          FeatureLayer,
          Extent,
          InfoTemplate
          var bounds = new Extent({
            "xmin":-16045622,
            "ymin":-811556,
            "xmax":7297718,
            "ymax":11142818,
            "spatialReference":{"wkid":102100}
          var map = new Map("map", {
            extent: bounds
          var url = "http://services3.arcgis.com/HVjI8GKrRtjcQ4Ry/arcgis/rest/services/Major_World_Cities/FeatureServer/0";
          var template = new InfoTemplate("Cities", "City: ${CITY_NAME}");
          var fl = new FeatureLayer(url, {
            infoTemplate: template
          map.addLayer(fl);
    </script>
  </head>
  <body>
    <div id="map"></div>
  </body>
</html>
SteveCline
Robert -
I am trying to integrate that into my script by doing this:
var template = new InfoTemplate("cities", "City: ${CITY_NAME}");
  var cities = new FeatureLayer("http://services3.arcgis.com/HVjI8GKrRtjcQ4Ry/arcgis/rest/services/Major_World_Cities/FeatureServer/0", {
        legendLayers.push({
          layer: cities,
          title: 'World Cities'
Can you see what I am missing?
Steve
Steve,
   Do you have the require for InfoTemplate in your code?
SteveCline
Robert -
I was able to get it to work just like yours.  However, on both of our scripts the attribute for the "CITY_NAME" field does not appear in the pop-up. (see attachment)
Also, am I correct in assuming that if I want to change the symbology on these point features I will need to do that in desktop and republish?
Thanks again.
Steve
Steve,
  The city name not showing up in the popup is because I forgot to specify the outFields of the feature layer:
            infoTemplate: template,
You could change the symbology on the layer in Desktop and re-publish as you said or you just use  setRenderer on the FeatureLayer.
require([
        "esri/map",
        "esri/renderers/SimpleRenderer",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/Color",
        "dojo/domReady!"
      ], function(
          domConstruct,
          Map,
          FeatureLayer,
          Extent,
          InfoTemplate,
          SimpleRenderer,
          SimpleMarkerSymbol,
          Color
            "xmin":-16045622,
            "ymin":-811556,
            "xmax":7297718,
            "ymax":11142818,
            extent: bounds
            outFields: ["*"]
          var sms = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 10, null, new Color([0,255,0,0.25]));
          fl.setRenderer(new SimpleRenderer(sms));
          map.addLayer(fl);
EvelynHernandez
Steve,
I have this as example, i hope this work for u too:
    var trans = new InfoTemplate();
        trans.setTitle("<b>ID: ${concesion_id}</b>");
        var transInfoContent =
        "<div style=padding-top: 10px;>Class: ${class}<br></div>" +
        "<div style=display:inline-block;width:8px;></div>";
        trans.setContent(transInfoContent);
//ADD Templates to MapServer
        chqMapServer.setInfoTemplates({
        0:{  infoTemplate: trans}
//adding the layer to the map
  map.addLayer(chqMapServer);
Verify the attributes in ${} have the same name how they were specified in ur rest srv.
SteveCline
Robert -
I tried this:
    var template = new InfoTemplate("Cities", "City: ${CITY_NAME}<br>Population: ${POP}");
    var Cities = new FeatureLayer("http://services3.arcgis.com/HVjI8GKrRtjcQ4Ry/arcgis/rest/services/Cities_over_100000/FeatureServer/0", {
      outFields: "[CITY_NAME]"
The result of this script is that the layer does not appear at all.  When I remove the
It appears again but it only shows the population attribute, not the city attribute.
Steve
