how to call modules in arcgis javascript api
5526
05-08-2015 04:37 AM
ugrgr
how to pass parameters like combobox selected items into module from html page and how to call back that module  into html page in arcgis api for javascript, Please give me some sample code to learn.
RobertScheitlin__GISP
ugr gr,
   Have you seen the JS api samples page?
Samples | ArcGIS API for JavaScript
ChrisSmith7
Honored Contributor
If you are looking for creating user modules and using them in your application, check out:
Point clustering | ArcGIS API for JavaScript
So, at the top of the main application, you'll see a script tag for dojo config:
    <script>
// helpful for understanding dojoConfig.packages vs. dojoConfig.paths:
// http://www.sitepen.com/blog/2013/06/20/dojo-faq-what-is-the-difference-packages-vs-paths-vs-aliases/
var dojoConfig = {
        paths
          extras
: location.pathname.replace(/\/[^/]+$/, "") + "/extras"
</script>
The "extras" param will specify the directory to pull the modules. You can then include it like you would an Esri/dojo module:
      var map;
      require
"extras/ClusterLayer"
], function(
ClusterLayer
Here's where the module lives - http://developers.arcgis.com/javascript/samples/layers_point_clustering/extras/ClusterLayer.js. Then, you can instantiate and interact with the module:
            // cluster layer that uses OpenLayers style clustering
            clusterLayer
= new ClusterLayer({
"data": photoInfo.data,
"distance": 100,
"id": "clusters",
"labelColor": "#fff",
"labelOffset": 10,
"resolution": map.extent.getWidth() / map.width,
"singleColor": "#888",
"singleTemplate": popupTemplate
            clusterLayer.setRenderer(renderer);
            map
.addLayer(clusterLayer);
Hope this helps!
