Layer onLoad event, how to handle an error
4786
6
11-03-2010 11:40 AM
mikewebster
So to load a layer is straight forward as taken from the "JavaScript API Concepts" page. Sniplet below...
function init() {
  var layer = new esri.layers.ArcGISDynamicMapServiceLayer(...);
  dojo.connect(layer, "onLoad", printInitialExtent);
How do you catch an event if the layer never gets loaded? Maybe the service is down. If the layer does not get loaded I want to inform the user (rather than a blank map).
MarcelKleinmann
Good question.
I would be interrested in a solution to that problem as well.
My first approach was, checking the url seperately by an independent request through a xmlHttpObject. But I couldn't get it running from my jsp till now.
Has anyone a solution?
Cheers
StewartMcCall
I use the following...
dojo.connect(layer, "onError", errorHandling);
...with errorHandling a function that tells the user the GIS isn't available.  I do a redirect to a standard GIS unavailable page.
Hope this is what you are looking for...
Cheers
mikewebster
OK, that is what I expected. That is the first thing I tried and my onError event for that layer never gets called.
function init() {
  dojo.connect(layer, "onLoad", loadHandling);
I will try it again in a simple app and see if I can get it working.
MarcelKleinmann
This dojo.connect(layer, "onError", errorHandling); does it for me.
Cheers
mikewebster
yes it was this simple. i had a elementary mistake in my code. now the onError event works as expected. thanks for confirming the event works as expected.
HemingZhu
function init() {
try this:
function init() {
  dojo.connect(layer, "onError", function(error){
       alert ("There is a problem on loading the layer!");
