Hi there,
I am trying to populate a Facility ID in a feature class that has 7000+ features using Attribute Assistant and Generate_ID as the value method. This works great if I manually select less than 1000 features and run the create rules for selected features. As soon as I select 1001 features or more and run the create rules for selected features, the rule starts over again and continues generating facility ID's in a sequence. It will eventually stop.
Here is the Value Info: swInlet|4|SWIN-[seq]
On create = True
On Change (attribute) = False
On Change (geometry) = False
Manual Only = False
Before I attempt to rerun I change the Sequence Counter in the GenerateID table back to 0.
The good news - I have already run the rules and created the Facility ID's less than 1000 at a time so my feature class is populated and I can move on.
I just want to know why it is doing this...
Thanks!!
-Jessica
