Error inserting new column in ArcSDE table (ERROR 999999)
4438
04-29-2015 08:30 AM
MikelSantamaria
I am using a python script to populate a table with values I get from rasters files. I use arcpy.AddField_management to add a new column and  arcpy.CalculateField_management to insert the values for the new column. The table has more than 450 columns and after executing arcpy.CalculateField_management I get the following error:
ExecuteError: ERROR 999999: Error executing function. Underlying DBMS error [[Microsoft][SQL Server Native Client 11.0][SQL Server]Cannot create a row of size 8074 which is greater than the allowable maximum row size of 8060.] Failed to execute (CalculateField).
I can avoid this error executing in SQL Server:
ALTER TABLE REBUILD
Is there anyway to execute this SQL server instruction from the script or another equivalent way to avoid the error?
Tags (3)
