Loading a grid from a buffer graphics
4922
04-29-2015 04:41 AM
IbrahimHussein
Hey guys,
I am trying to buffer a zone, and put the results of that buffer onto a grid. I was able to buffer and do the query, but I cant seem to load the grid with the results.
Edit fiddle - JSFiddle  on line 497 is where I call the function to populate the grid.
499 -
var data = array.map(feat.features, function(feature) {
feat is a variable with the results. doing a console log on the feat.features shows the results, so I know its passing thru.
lines 510,511 is where I set the results onto the grid, but nothing shows up.
Any ideas what I'm doing wrong?
JakeSkinner
Esri Esteemed Contributor
Hi Ibrahim,
It looks like you are trying to implement different types of Grids (i.e. "dgrid/OnDemandGrid", "dojox/grid/DataGrid").  I would recommend selecting one of these and working with that.  Here is an example that has the functionality you are looking for using the "dojox/grid/DataGrid" module.
JakeSkinner
Hi Ibrahim,
IbrahimHussein
Hey Jake,
Thanks ill take a look.
edit - went with the datagrid route and ditched ondemandgrid route. works great, thanks again jake.
