Query Layer in ArcMap 10.2.2 - Visual doesn't match Attribute Table
3633
04-23-2015 05:58 AM
NicoleSchleifer
I've create a Query Layer to join multiple tables to one Parcel table with Geometry.
In ArcMap, it displays all the correct parcels. In Toad, it has a count of all the correct records.... but when I right-click on the Query Layer in ArcMap and select the Attribute Table it only show 19 out of the 3840 records.
Any suggestions?
ArcMap 10.2.2 - Oracle 11g
JeffWard
Honored Contributor
Can you post your query that creates the query layer?
Jeff Ward
Summit County, Utah
NicoleSchleifer
   SELECT f.folderyear || '-' || f.foldersequence || ' ' || f.foldertype
             permit_no,
          vs.statusdesc status,
          f.indate,
          TO_NUMBER (TO_CHAR (f.issuedate, 'YYYY')) issuedyear,
          f.issuedate,
          vsb.subdesc Permit_Bldg_Type,
          pi.propinfovalue Planning_Unit_Type,
          fi1.infovalue DC_Unit_Count,
          fi2.infovalue DC_Suite_Count,
          NVL (fi3.infovalue, fi4.infovalue) Units_Created,
          fi4.infovalue Apts,
             p.prophouse
          || p.propstreet
          || p.propstreettype
          || p.propstreetdirection
          || p.propunit
             Address,
          p.propertyroll,
          p.propplan,
          TRUNC (fp3.enddate) HVACOCCDT,
          TRUNC (fp2.enddate) PLUMBINGOCDT,
          TRUNC (fp1.enddate) BUILDINGOCCDT,
          pp.shape,
             f.folderyear
          || f.foldersequence
          || f.foldertype
          || p.propertyroll
             Uniqueid
     FROM whadmin.cty_folder f,
          whadmin.cty_property p,
          whadmin.cty_validfolder vf,
          whadmin.cty_folderinfo fi1,
          whadmin.cty_folderinfo fi2,
          whadmin.cty_folderinfo fi3,
          whadmin.cty_folderinfo fi4,
          whadmin.cty_propertyinfo pi,
          whadmin.cty_validstatus vs,
          whadmin.cty_validsub vsb,
          whadmin.cty_folderprocess fp1,
          whadmin.cty_folderprocess fp2,
          whadmin.cty_folderprocess fp3,
          gisadmin.parcel pp
    WHERE     f.propertyrsn = p.propertyrsn
          AND f.indate > '1-jan-00'
          AND f.statuscode IN (20, 30, 350)
          AND f.foldertype = vf.foldertype
          AND vf.foldergroupcode = 1
          AND f.statuscode = vs.statuscode
          AND f.subcode = vsb.subcode
          AND p.propertyrsn = pi.propertyrsn(+)
          AND pi.propertyinfocode(+) = 65
          AND f.folderrsn = fi1.folderrsn(+)
          AND fi1.infocode(+) = 14
          AND f.folderrsn = fi2.folderrsn(+)
          AND fi2.infocode(+) = 185
          AND f.folderrsn = fi3.folderrsn(+)
          AND fi3.infocode(+) = 3
          AND f.folderrsn = fi4.folderrsn(+)
          AND fi4.infocode(+) = 25
          AND TO_NUMBER (NVL (fi3.infovalue, fi4.infovalue)) > 0
          AND f.folderrsn = fp1.folderrsn(+)
          AND fp1.processcode(+) = 39
          AND f.folderrsn = fp2.folderrsn(+)
          AND fp2.processcode(+) = 40
          AND f.folderrsn = fp3.folderrsn(+)
          AND fp3.processcode(+) = 405
          AND pp.name = p.propertyroll;
VinceAngelo
Esri Esteemed Contributor
Oracle has supported the SQL-standard JOIN syntax for a while now.  If nothing else, using that syntax will make life easier on your optimizer.
AnnalieseVollick
I haven't dealt much with Query Layers, but for those I have, I would suspect a problem with the Unique ID.
