Import TIFF (into webmap App) error
6350
7
04-14-2015 07:06 AM
KarolinaKorzeniowska
I am trying to import TIFF layer into my webmap. However, I am receiving an error that my layer cannot be added to my map. Below is a short description what I did:
1. My content > Add Item > From my computer > *.tif
2. *.tif > Share > Everyone
3. copy of *.tif URL
4. (My web map) > Add > Add Layer from Web > paste of URL > and here I always have an error that my layer cannot be added.
I would be grateful for some tips how to solve this issue.
JakeSkinner
Esri Esteemed Contributor
Hi Karolina,
You will not be able to add the TIFF directly to a web map.  If you navigate to the uploaded image and hover over OPEN, you will only have the option 'Download'.
You will need to create a ArcGIS Online tiled service or an ArcGIS Server Tiled/Dynamic/Image Service.  Here is a helpful document that provides the steps to create an ArcGIS Online tiled service.
Hi Jake,
Thank you for detailed instruction. I tried to follow it, but I received an error for which I cannot find an answer. I generated tile cache, next I tried to apply Manage Tile Cache, and here I have an error. In the field "Import Tiling Scheme" I cannot choose my Tile Cache Tiling Scheme, I am receiving this error:
001480 : Data source spatial reference does not match tiling scheme spatial reference.
I checked this and the spatial reference is fine, so I do not know what is wrong. Do you have some ides how to skip this?
Thanks in advance.
JakeSkinner
What is the spatial reference you are trying to use to create the tile cache?
I am not specifying spatial reference. I am assuming that it is automatically taken from my input data, right? In my input data I have GCS_WGS_1984, and in my generated Tile cache Tiling Scheme I also have GCS_wGS_1984.
JakeSkinner
For the 'Input Data Source' within the Manage Tile Cache tool, are you specifying the TIFF image?
If so, can you send a screen shot of the coordinate system in the properties?  Ex:
Can you also attach the tiling scheme file you created?
Yes, for the 'Input Data Source' within the Manage Tile Cache tool, I am specifying the TIFF image.
My TIFF file properties:
My Tile Cache Tiling Scheme:
<?xml version="1.0" encoding="utf-8" ?><CacheInfo xsi:type='typens:CacheInfo' xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance' xmlns:xs='http://www.w3.org/2001/XMLSchema' xmlns:typens='http://www.esri.com/schemas/ArcGIS/10.3'><TileCacheInfo xsi:type='typens:TileCacheInfo'><SpatialReference xsi:type='typens:GeographicCoordinateSystem'><WKT>GEOGCS[&quot;GCS_WGS_1984&quot;,DATUM[&quot;D_WGS_1984&quot;,SPHEROID[&quot;WGS_1984&quot;,6378137.0,298.257223563]],PRIMEM[&quot;Greenwich&quot;,0.0],UNIT[&quot;Degree&quot;,0.0174532925199433],AUTHORITY[&quot;EPSG&quot;,4326]]</WKT><XOrigin>-400</XOrigin><YOrigin>-400</YOrigin><XYScale>11258999068426.238</XYScale><ZOrigin>-100000</ZOrigin><ZScale>10000</ZScale><MOrigin>-100000</MOrigin><MScale>10000</MScale><XYTolerance>8.983152841195215e-009</XYTolerance><ZTolerance>0.001</ZTolerance><MTolerance>0.001</MTolerance><HighPrecision>true</HighPrecision><LeftLongitude>-180</LeftLongitude><WKID>4326</WKID><LatestWKID>4326</LatestWKID></SpatialReference><TileOrigin xsi:type='typens:PointN'><X>-400</X><Y>400</Y></TileOrigin><TileCols>256</TileCols><TileRows>256</TileRows><DPI>96</DPI><PreciseDPI>96</PreciseDPI><LODInfos xsi:type='typens:ArrayOfLODInfo'><LODInfo xsi:type='typens:LODInfo'><LevelID>0</LevelID><Scale>250000000</Scale><Resolution>0.59486525145757008</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>1</LevelID><Scale>125000000</Scale><Resolution>0.29743262572878504</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>2</LevelID><Scale>64000000</Scale><Resolution>0.15228550437313793</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>3</LevelID><Scale>32000000</Scale><Resolution>0.076142752186568963</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>4</LevelID><Scale>16000000</Scale><Resolution>0.038071376093284481</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>5</LevelID><Scale>8000000</Scale><Resolution>0.019035688046642241</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>6</LevelID><Scale>4000000</Scale><Resolution>0.0095178440233211203</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>7</LevelID><Scale>2000000</Scale><Resolution>0.0047589220116605602</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>8</LevelID><Scale>1000000</Scale><Resolution>0.0023794610058302801</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>9</LevelID><Scale>500000</Scale><Resolution>0.00118973050291514</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>10</LevelID><Scale>250000</Scale><Resolution>0.00059486525145757002</Resolution></LODInfo></LODInfos></TileCacheInfo><TileImageInfo xsi:type='typens:TileImageInfo'><CacheTileFormat>MIXED</CacheTileFormat><CompressionQuality>75</CompressionQuality><Antialiasing>false</Antialiasing><BandCount>1</BandCount><LERCError>0</LERCError></TileImageInfo><CacheStorageInfo xsi:type='typens:CacheStorageInfo'><StorageFormat>esriMapCacheStorageModeCompact</StorageFormat><PacketSize>128</PacketSize></CacheStorageInfo></CacheInfo>
I re-installed my ArcGIS, and now problem with spatial reference does not occur. However, another error appeared:
001483 : Failed to write cache configuration to : <value>.
Make sure you have write permissions to the directory where the cache configuration is written.
I tried also to add my data in different way using "Share as service" - with a partly success. I was able to import my data into the map. However, I cannot check the pixel value of my raster layer. It is displayed as a graphic without the possibility to check the raster values.
