Configure this widget - Sidebar controller - Not loading
4957
6
04-08-2015 08:53 AM
BrianDudek
Whenever I go into edit mode of the developers edition and click configure this widget under the widgets tab, all I get is a loading symbol with none of the options ever loading.  They loaded before and after I added the custom widget, but now all of a sudden they no longer load.  I can't determine why.
All of the regular non-sidebar controller widgets load their configurable options.
Any idea why?  Thanks.
RobertScheitlin__GISP
Brain,
   Check your browsers web console and you will likely find an error given when you attempt to load that widgets settings page.
BrianDudek
TypeError: Cannot read property 'version' of undefined {stack: (...), message: "Cannot read property 'version' of undefined"} "TypeError: Cannot read property 'version' of undefined
    at declare._upgradeWidgetConfig (webappbuilder/stemapp/jimu.js/WidgetManager.js:536:44)
    at null.<anonymous> (webappbuilder/stemapp/jimu.js/WidgetManager.js:503:25)
    at https://js.arcgis.com/3.12/init.js:177:296
    at k (https://js.arcgis.com/3.12/init.js:199:431)
    at then.b.then (https://js.arcgis.com/3.12/init.js:202:308)
    at declare.tryLoadWidgetConfig (webappbuilder/stemapp/jimu.js/WidgetManager.js:502:53)
    at t.initWidgetAttr (webappbuilder/builder/js/app/main.js:197:254)
    at t.init (webappbuilder/builder/js/app/main.js:192:317)
    at t.startup (webappbuilder/builder/js/app/main.js:192:202)
    at t._onEditWidget (webappbuilder/builder/js/app/main.js:142:177)
Okay.  Not sure quite yet on what all of this means.
Brain,
   What version of WAB are you using? Did you have a previous version that you upgraded?
BrianDudek
1.0.  Never upgraded.
Brain,
  Strange. Sounds like you need to get on the phone with tech support and file a bug.
BrianDudek
Yeah maybe.  I noticed when it fails to load, switching to the foldable theme does allow the widget options to load in the configuration box, and if I switch it back to tabbed it continues to fails to load.  Also if I start a new app everything is fine at first.  So maybe that says something.  Likely custom widget causing a bug in the app somewhere.
