Feature Layer Select query problem
2642
04-08-2015 03:27 AM
NadirHussain
var myFeatureLayer = new FeatureLayer("http://dell-pc/ArcGIS/rest/services/SirenFeatureService/FeatureServer/1", {
          mode: FeatureLayer.MODE_SELECTION,
          outFields: ["SIREN_NO", "Reg_E", "Reg_A", "Featuer_Type", "Description", "Location", "POINT_X"]
map.on("click", function(evt) {
            try
            selectQuery.geometry  =evt.mapPoint;
           myFeatureLayer.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW, function(features) {
               if (features.length > 0) {
                //store the current feature
                updateFeature = features[0];
                map.infoWindow.setTitle(features[0].getLayer().name);
                map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
              else {
                map.infoWindow.hide();
            }//try
            catch (err) {
                     txt = "There was an error on this page.\n\n";
                     txt += "Error description: " + err.message + "\n\n";
                     txt += "Click OK to continue.\n\n";
                     alert(txt);
in above code featurelayer 1 is point layer and its symbols are picturemarker symbol in symbology.if i click on this symbol feature return 0.Even i check it returns the x and y point..if i change the feature layer number like 3,which is my polygon layer.it is simplefillsymbol in symbology.when i click on this it give me the feature.what can be the reason.might be the line is any  selectQuery.geometry  =evt.mapPoint is any problem.this works for polgon layer not work for point layer.
please help.
RobertScheitlin__GISP
Nadir,
  I use this function to change the point into a extent so that point selection works.
pointToExtent: function(objPoint, distance){
  var clickOffset = distance || 6;
  var centerPoint = new Point(objPoint.x,objPoint.y,objPoint.spatialReference);
  var mapWidth = map.extent.getWidth();
  var pixelWidth = mapWidth/map.width;
  var tolerance = clickOffset * pixelWidth;
  var queryExtent = new Extent(1,1,tolerance,tolerance,objPoint.spatialReference);
  return queryExtent.centerAt(centerPoint);
