Is it possible to integrate workflow in application built with arcgis online ?
4051
04-07-2015 01:42 AM
DIALLOAbdoulaye
Hello Every One,
As a beginner with Esri's technology, i would like know if it's possible to integrate Arcgis workflow manager in arcgis online ?
if yes how ?
I confess I am lost, so if anyone can give me links which  explains simply the concept of Arcgis workflow manager it will be great.
Thanks in advance for any help or orientation
TopeBello
Hi Abdoulaye,
Yes you can, but it would request you modify the source code of the application templates that you use in ArcGIS online. Workflow Manager Server extension provides you with Flex, JavaScript and Silverlight APIs that you could use to make calls to a workflow manager service. For example, you can have a button to create a new job on your application. You can also pull job related information by using some of the existing queries configured on the desktop or you could form your own query on the fly.
I hope this helps!
Take a look at this video from the latest Developers conference on how to integrate workflow manager into a standalone application – http://video.esri.com/watch/3263/getting-started-with-the-workflow-manager-web-apis
Tope
