JSON to Features crashes ArcMap or Python if run from ArcPy
4651
04-03-2015 02:30 AM
WhereMatters
When you run arcpy.JSON_to_features using the attached json file. It just crashes python. I am using 10.3.
The json is actually the result of this 1=1 query. Click the link and save the output to a .json file.
If you use ArcMap and try to run the JSON to features tool with the attached JSON, then it would just keep running forever and ever.
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi Anand,
Is this the only JSON file that you are running into issues with?  Are you able to reproduce this crash with any other JSON file?
WhereMatters
I tried with other services on sampleserver6. It works on all other services. Its just this one its crashing on.
I am seeing that it crashes on all layers in this mapservice:
Energy/Geology (MapServer) http://sampleserver6.arcgisonline.com/arcgis/rest/services/Energy/Geology/MapServer
