iOS Collector Feature Request - Online layer + Offline maps
3976
04-02-2015 06:00 AM
BledarBirbo1
Hi.
Here is another Real World Example not supported by the Arcgis Collector.
Our user need to have 3 editable layers on an iPAD with 3G connection and will be collecting data on the field.
They also need to overlay 4 or 5 different non- editable layers during the collection.
Now they can do that when they use the Online map through the 3G connection.
The problem is when they need to take photos as attachments.  It takes FOREVER to snap a photo and continue the collection when the map is online. The collector app is totally frozen during this process and make the online map option not viable.
So we had to make an offline map , but then realized that we can't have those 4-5 read-only extra layers on the same map.
Our request is:
Modify the iOS Collector app to let users enter one or more online layers and be able to switch those on or off independently of the Map type.
Currently we are stuck, and have no workaround.
Thanks.
Tags (1)
RussRoberts
Esri Notable Contributor
If you are using feature services you can disable the editing on those layers in the web map and take the entire map offline. If you have 10.3 server or using hosted and 10.3 Collector we support the different editing capabilities and you can disable editing and take those feature services offline.
Russ
BledarBirbo1
Hi Russell
Here are a couple of reasons why we cannot implement the map in the way that you suggested.
  • We are using server 10.2.2
  • We cannot publish Feature Services for the read-only layers, those extra layers are published as MapService only.
  • We need to access 3rd party layers not hosted on our ArcGIS Server.
RussRoberts
Map Services cannot be taken offline with the ability to query the features in that offline state. They can only be viewed as tiled layers. We are hoping to make an enhancement to Collector to be able to pick a compressed image size but that will not be in the next release.
Russ
