Layer toggle with info window
528
10-01-2010 12:39 PM
OscarMonell
Hi!
I�??ve been building some Javascript applications based on the sample section at ESRI resource center.
I consider myself being a newbie on javascript, so now when I need to extend the samples, I get stuck!
What I need to do is to make this application
http://kartweb.staffanstorp.se/kommunkarta.htm (based on http://resources.esri.com/help/9.3/arcgisserver/apis/javascript/arcgis/help/jssamples/map_agol.html )
a bit more informative, by adding a drop down list with a dynamic layer toggle on/off,
something like this: http://kartweb.staffanstorp.se/kommunkarta_test.htm
I�??m looking for a mapping application similar to Google maps and it�??s �??More�?��?� button.
I see the functionality here http://resources.esri.com/help/9.3/arcgisserver/apis/javascript/arcgis/help/jssamples/map_dynamiclay...
but don�??t know how to extend my original functionality with this as well.
To make this municipality map even more informative, I need the dynamic layer to be able to query/identify.
I have implemented the query code on this application http://kartweb.staffanstorp.se/befintliga_planer.htm but once again:
I get lost in the code when trying to merge the applications together�?�
I would appreciate any help, and do apologize for the bad coding language in my applications�?�
Regards
