I wrote the tool and all I would change is that the Index contour is usually every 4th or 5th contour (as described in Eduard Imhof's Cartographic Relief Representation). If you have 5m contours (1k or 2k), then 25m would be your index. If you have 10meters contour interval, your index contour would be at 50m (4k or 9k scales). You don't want to be too heavy with your contours and this can be adjusted for different areas of terrain depend on the community you are in. We recently did all of Spain at 5m contours and then used the 10m intervals with 50m indexes at 9k and 18k, etc. Attached is an example of contours symbolized correctly for the index at that scale.
Arthur Crawford
ESRI St. Louis
