graphic infoTemplate not displaying in 3.10+ Javascript API
4247
03-26-2015 01:43 PM
JaniceBaird
I have been using the reverse geocoding successfully in javascript 3.9 api. When I click on the map, a graphic is added with the text displaying the address. Then, if I click on the graphic a infoWindow opens with the Address. After switching to 3.10, I still get the graphic with the address text but instead of getting a infoWindow when I click on the graphic I get another graphic on top of the first one. The only change I have made in my application is from 3.9 to 3.10 (I also tried 3.13 with the same results as 3.10). Anyone else find this behavior?
JaniceBaird
OK. I got it working but find it interesting that the following code works in 3.9 with the map.infoWindow lines commented out but not in 3.10. 3.10 still adds another graphic when I click on the graphic but I do get the infoWindow.
                        var textSymbol = new TextSymbol(address.Street, font, textColor);
                        textSymbol.yoffset = 8;
                        var symbol = new SimpleMarkerSymbol()
                            .setStyle("square")
                            .setColor(symColor);
                        var addAtt = { "Address": address.Street, "Zip": address.ZIP };
                        var graphic = new Graphic(location, symbol, addAtt, infoTemplate);
                        var textGraphic = new Graphic(location, textSymbol);
                        map.graphics.add(textGraphic);
                        map.graphics.add(graphic);
                        //map.infoWindow.setTitle(graphic.getTitle());
                        //map.infoWindow.setContent(graphic.getContent());
                        //map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
What I am trying to do is reverse geocode and have a graphic with text display at the location without the infoWindow. When the user clicks on the graphic, the infoWindow displays.
