Is there a way to turn off need for cookies for services?
3018
03-26-2015 12:20 PM
PhilipKnight1
I currently have an issue where I am getting a pop-up message asking to download a cookie when I am using my app. I have posted this on Stack Overflow: javascript - Using showModalDialog (IE 9+) causes cookie prompt - Stack Overflow
This issue only happens on my client's domain computers. Everything works just fine here. The pop-up occurs for each layer in my app, but does not seem to have any effect if I say "no" to downloading the cookie. I have also determined that the issue ONLY occurs when the page is being opened via "window.showModalDiaglog". If I go directly to the web page, I have no issues what so ever.
I have turned on and also tried turning off all cookies and the issue still is present (also described in stack overflow question).
I have also determined that the following examples below exhibit the same issue, where a pop-up is presented asking for the user to download a cookie. What do the following examples have in common that would require a cookie be downloaded.
Label Layer | ArcGIS API for JavaScript
Identity Manager with info persisted client side | ArcGIS API for JavaScript
Any projection | ArcGIS API for JavaScript
Mobile ArcGIS.com | ArcGIS API for JavaScript
sites that DON'T show the issue on the client's machine
Basic service area | ArcGIS API for JavaScript
Directions | ArcGIS API for JavaScript
Geolocation with a temporal renderer | ArcGIS API for JavaScript
Class breaks renderer | ArcGIS API for JavaScript
Explore Heat Maps | ArcGIS API for JavaScript
Proportional symbols for lines | ArcGIS API for JavaScript
Smart Mapping - Show Data by Color | ArcGIS API for JavaScript
Use Heat Maps | ArcGIS API for JavaScript
Query data without a map | ArcGIS API for JavaScript
Manage results from multiple queries | ArcGIS API for JavaScript
---- UPDATE - EDIT ----
doing nothing more than executing the following code causes the issue:
var fLayer = new esri.layers.FeatureLayer(featureLayerURL);
Is there some way to turn off the need for the service to request a cookie?
Message was edited by: Philip Knight
PhilipKnight1
I have determined/stronly suspect that the issue is that the service is protected with a cookie. I get a pop-up only when using showModalDialog though, using window.open does not require the cookie for some reason.
