Can you remove the basemap using BasemapGallery?
5900
09-30-2010 08:01 AM
BenSayers
I am trying compile my own basemap gallery, I have it all working, except I would like to provide users with the option to turn off all underlying Tiled Map layers as sometimes the imagery gets in the way of the features.
This is what I have:
function createBasemapGallery(){
       var basemaps= [];
        var imageryLayer = new esri.dijit.BasemapLayer({
          url:"http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"
        var imageryBasemap = new esri.dijit.Basemap({
          layers:[imageryLayer],
          title:"Imagery",
          thumbnailUrl:"images/imageryThumb.jpg"
        basemaps.push(imageryBasemap);
  var boundariesLayer = new esri.dijit.BasemapLayer({
          url:"http://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer"
        var imageryBoundariesBasemap = new esri.dijit.Basemap({
          layers:[boundariesLayer,imageryLayer],
          title:"Imagery (labels)",
          thumbnailUrl:"images/imagery_labelsThumb.jpg"
        basemaps.push(imageryBoundariesBasemap);
  var topographicLayer = new esri.dijit.BasemapLayer({
          url:"http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"
        var topographicBasemap = new esri.dijit.Basemap({
          layers:[topographicLayer],
          title:"Topographic",
          thumbnailUrl:"images/topographicThumb.jpg"
        basemaps.push(topographicBasemap);
  var streetLayer = new esri.dijit.BasemapLayer({
          url:"http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"
        var streetBasemap = new esri.dijit.Basemap({
          layers:[streetLayer],
          title:"Street Map",
          thumbnailUrl:"images/streetThumb.jpg"
        basemaps.push(streetBasemap);
  var terrainLayer = new esri.dijit.BasemapLayer({
          url:"http://services.arcgisonline.com/ArcGIS/rest/services/World_Terrain_Base/MapServer"
        var terrainBasemap = new esri.dijit.Basemap({
          layers:[terrainLayer],
          title:"Terrain Map",
          thumbnailUrl:"images/terrainThumb.jpg"
        basemaps.push(terrainBasemap);
  var noneLayer = new esri.dijit.BasemapLayer({
          url:"http://"
        var noneBasemap = new esri.dijit.Basemap({
          layers:[noneLayer],
          title:"None",
          thumbnailUrl:"images/noneThumb.jpg"
        basemaps.push(noneBasemap);
        var basemapGallery = new esri.dijit.BasemapGallery({
         showArcGISBasemaps:false,
         basemaps:basemaps,
         map:map
        },"basemapGallery");
        basemapGallery.startup();
        dojo.connect(basemapGallery, "onError", function(error) {console.log(error)});
When I click on None the map doesn't change and whichever was the previous selected basemap stays active.
Any ideas?
BillDaigle
The following seems to work:
var noBaseMap = new esri.dijit.Basemap({
      layers:[],
      title:"None",
      thumbnailUrl:"images/none.jpg"
  basemaps.push(noBaseMap);
BillDaigle
One way to do this is to search all map layers and look for the "_basemapGalleryLayerType" property.  If it is set to "basemap", then you can simply hide the layer.
It works in 2.2.  I haven't tried it with the other versions of the API, so I'm not sure if the "_basemapGalleryLayerType" property is always available or not.
Here's what my function looks like:
 hideBaseMap: function(){
    var _this = this;
    dojo.forEach(this.map.layerIds, function(id){
      var layer = _this.map.getLayer(id);
      if (layer._basemapGalleryLayerType === "basemap") {
        layer.hide()
JayThakur
I want to customize my basemap gallery. I want to remove streets and streets and openstreetmap from the gallery, all the remaining basemaps are still there in the gallery.
I tried using BasemapGallery | API Reference | ArcGIS API for JavaScript the function
function removeBasemap(id){
  basemapGallery
.remove(id);
and also just basemapGallery.remove(galleryNode_basemap_7) as shown in the bellow image;remove_basemap.PNG
But dint work. can someone help me in removing those two basemaps from the basemap gallery.
Thanks in advance.
BillDaigle
You'll need to wait for the basemap to load before using the 'remove' function.
basemapGallery.on('load',function(){
  basemapGallery.remove('basemap_2');
  basemapGallery.remove('basemap_9');
