Filtering layer, please I newbie !!!
1287
09-22-2010 06:50 PM
ChristianBocaz
Please, I need help with this problem.
I have a layer with 5 lines as roads, and all of they with a geocode.
Also, i have a mxd as a map service in a ArcGis Server 9.3.
I need to put the map of the service  in a webpage across Esri Javascript, but filtering the roads across a GET or POST variable and highlight this road.
Please....help me !! and sorry for my english.
Christian
ChristianBocaz
Christian
Hi, I found the way to make a query and create a symbol over tha roads...but,,, I can't make that after query, center and zoom to the query result....
Please, can you help me ??...
here is my code:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <title>test</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.1/js/dojo/dijit/themes/tundra/tundra.css">
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.1"></script>
    <script type="text/javascript">
   dojo.require("esri.map");
      dojo.require("esri.tasks.query");
   dojo.require("esri.symbol");
      dojo.require("esri.layers.agstiled");
      dojo.require("esri.toolbars.draw");
   var map;
      var myQueryTask, myQuery;
   var infoTemplate;
   var symbol;
      function init() {
  //create map and add layer
  map = new esri.Map("mapDiv");
  var layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://gis/ArcGIS/rest/services/MOP/MapServer");
  map.addLayer(layer);
        //build query
        myQueryTask = new esri.tasks.QueryTask("http://gis/ArcGIS/rest/services/MOP/MapServer/10");
        //build query filter
        myQuery = new esri.tasks.Query();
        myQuery.returnGeometry = true;
        myQuery.outFields = ["CodUnico","Nombre","Dire"];
    //initialize InfoTemplate
  infoTemplate = new esri.InfoTemplate("${CodUnico}", "Nombre : ${Nombre}<br/> Dire : ${Dire}");
  //create symbol for selected features
  symbol = new esri.symbol.SimpleMarkerSymbol();
  symbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE);
  symbol.setSize(10);
  symbol.setColor(new dojo.Color([255,0,0,0.5]));
      function execute(CodUnico) {
        myQuery.where = "CodUnico like '%" + CodUnico + "%'";
        //execute query
        myQueryTask.execute(myQuery,showResults);
      function showResults(myFeatureSet) {
        var s = "";
        for (var i=0, il=myFeatureSet.features.length; i<il; i++) {
          var featureAttributes = myFeatureSet.features.attributes;
          for (att in featureAttributes) {
            s = s + "<strong>" + att + ": </strong>" +
   featureAttributes[att] + "<br />";
        dojo.byId("info").innerHTML = s;
    //remove all graphics on the maps graphics layer
    map.graphics.clear();
    //Performance enhancer - assign featureSet array to a single variable.
    var resultFeatures = myFeatureSet.features;
    //Loop through each feature returned
    for (var i=0, il=resultFeatures.length; i<il; i++) {
      //Get the current feature from the featureSet.
      //Feature is a graphic
      var graphic = resultFeatures;
      graphic.setSymbol(symbol);
      //Set the infoTemplate.
      graphic.setInfoTemplate(infoTemplate);
      //Add graphic to the map graphics layer.
      map.graphics.add(graphic);
      dojo.addOnLoad(init);
    </script>
  </head>
  <body>
    <form action="">
      Geocodigo DAP :
      <input type="text" id="CodUnico" value="DAP101012" />
      <input type="button" value="Get Details"
onclick="execute(dojo.byId('CodUnico').value);" />
    </form>
    <br />
    <br /><div id="mapDiv" style="margin:auto;width:97%;border:1px solid #000;"></div>
    <div id="info" class="tundra" style="padding:5px; margin:5px; background-color:#eee;"></div>
  </body>
</html>
any idea ?
TimRourke
Christian,
If you put the graphics in an array as you add them to the map, you can get the extent of the graphics using esri.graphicsExtent.
See:
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi_start.htm#jsapi/namespace_esri.htm#esr...
ChristianBocaz
finally I found the way to make it.
But now, i have to draw N objects as Points, Polygon and Polylines all in the same query task.
My problem here is about how can set the extent for the N objects.....like ArcMap do it ?
some one can help me ?
