Custom widget error
6111
8
03-24-2015 01:44 PM
ChristopherOlsen
I'm having the same issue with custom widgets- using WAB 1.1.  In using Robert Scheitlin, GISPwidgets, only the basemap widget works without any issues.  Share and Elevation Profile will throw this error.  Other custom widgets also seem to throw the error as well.
RobertScheitlin__GISP
Christopher,
   Did you add the new widget to your client\stemapp\widgets AND your actual apps copy of that widget
server\apps\xx\widgets?
Christopher,
   For the elevation widget, I have not put out a version that works with 1.1 yet. In version 1.1 of Web AppBuilder something broke this widget and I have not had time to focus on getting a version out that works with 1.1. For the Share widget there is a 1.1.1 version available that I developed for 1.1.
ChristopherOlsen
Hi Robert,
Thanks for the quick reply... I redownloaded 1.1.1 and it's still having the same issue.  I've closed out of the app builder, restarted the bat file, cleared cache etc.  Fiddler doesn't show any errors either.
Chris
Chris,
     I branched this to a new question as it is really not the same as issue as the other thread.
Do you see anything in your browsers web console.
ChristopherOlsen
panel [widgets/Share/Widget_19_panel] created.
WidgetManager.js:101 create [widgets/Share/Widget] error:TypeError: Cannot read property 'remove' of null
    at declare._setExtentChecked (http://computer.esri.com:3344/webappbuilder/apps/2/widgets/Share/Widget.js:119:25)
    at declare.postCreate (http://computer.esri.com:3344/webappbuilder/apps/2/widgets/Share/Widget.js:67:14)
    at k.create (http://js.arcgis.com/3.13/init.js:1123:348)
    at k.postscript (http://js.arcgis.com/3.13/init.js:1122:99)
    at new <anonymous> (http://js.arcgis.com/3.13/init.js:108:192)
    at declare.createWidget (http://computer.esri.com:3344/webappbuilder/apps/2/jimu.js/WidgetManager.js:252:20)
    at null.<anonymous> (http://computer.esri.com:3344/webappbuilder/apps/2/jimu.js/WidgetManager.js:98:39)
    at g.hitch (http://js.arcgis.com/3.13/init.js:177:296)
    at k (http://js.arcgis.com/3.13/init.js:199:431)
    at m (http://js.arcgis.com/3.13/init.js:199:357)
init.js:209 TypeError: Cannot read property 'remove' of null {stack: (...), message: "Cannot read property 'remove' of null"} "TypeError: Cannot read property 'remove' of null
    rejected at a (http://js.arcgis.com/3.13/init.js:200:337)
    at k (http://js.arcgis.com/3.13/init.js:200:103)
    at x.reject (http://js.arcgis.com/3.13/init.js:202:143)
    at null.<anonymous> (http://computer.esri.com:3344/webappbuilder/apps/2/jimu.js/WidgetManager.js:105:25)
    at f.resolve (http://js.arcgis.com/3.13/init.js:201:441)
    at null.<anonymous> (http://computer.esri.com:3344/webappbuilder/apps/2/jimu.js/WidgetManager.js:162:17)
Error
    at f.then.b.then [as then] (http://js.arcgis.com/3.13/init.js:202:253)
    at null.<anonymous> (http://computer.esri.com:3344/webappbuilder/apps/2/jimu.js/BaseWidgetPanel.js:65:53)
    at Object.g.forEach (http://js.arcgis.com/3.13/init.js:229:250)
    at declare.loadAllWidgetsInOrder (http://computer.esri.com:3344/webappbuilder/apps/2/jimu.js/BaseWidgetPanel.js:55:13)
    at declare.startup (http://computer.esri.com:3344/webappbuilder/apps/2/jimu.js/BaseWidgetPanel.js:44:12)
    at n (http://js.arcgis.com/3.13/init.js:106:103)
    at declare.startup (http://computer.esri.com:3344/webappbuilder/apps/2/themes/FoldableTheme/panels/FoldablePanel/Foldabl...)
    at declare.startup (http://computer.esri.com:3344/webappbuilder/apps/2/themes/FoldableTheme/panels/FoldablePanel/Panel.j...)
    at null.<anonymous> (http://computer.esri.com:3344/webappbuilder/apps/2/jimu.js/PanelManager.js:96:19)"
Christopher,
   That is a bug in the 1.1.1 version I just fixed it and released 1.1.2
Share Widget Version 1.1.2 - 3/24/15
ChristopherOlsen
Still happening.  Here's the log:
    at http://js.arcgis.com/3.13/init.js:177:296
    at resolve (http://js.arcgis.com/3.13/init.js:201:441)
Error
    at then.b.then (http://js.arcgis.com/3.13/init.js:202:253)
Christopher,
ChristopherOlsen
That was it.  The folder was in there, but once I overrode the old files, the issue cleared up.  Thanks Robert!
