Trying to add a my own imagery layer and dynamic layer on a template.
3810
03-17-2015 02:03 PM
ChrisSergent
This is my first question of three where I am trying to convert a responsive web created Tom Wayson. His original app is here: tomwayson/responsive-citizens · GitHub
From my original app, I want to add the following:
// set custom extent
                var initialExtent = new Extent({
                    "xmin": 777229.03,
                    "ymin": 1133467.92,
                    "xmax": 848340.14,
                    "ymax": 1185634.58,
                    "spatialReference": {
                        "wkid": 3435
                // create map and set slider style to small
                map = new Map("mapDiv", {
                    showAttribution: false,
                    sliderStyle: "small",
                    extent: initialExtent,
                    logo: false
                // Starts initEditing after the feature layer(s) have been added
                map.on("layers-add-result", initEditing);
                // add imagery
                var tiled = new ArgGISTiledMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
                map.addLayer(tiled);
                // add operational layer
                var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", {
                    "opacity": 0.5
                map.addLayer(operationalLayer);
In the app that I am trying to add this information into, I believe I want to modify the following, but I am not sure how (the complete app is at: csergent45/streetSigns · GitHub
excerpt 1:
var config = {
 mapOptions: {
      basemap:'topo',
      center:[-117.1825, 34.0547],
      zoom:14,
      sliderPosition: 'bottom-right'
    citizenRequestLayerUrl: 'http://maps.decaturil.gov/arcgis/rest/services/test/StreetSignTest/FeatureServer/0',
    infoTemplate: {
      title: '<b>Request ${objectid}</b>',
      content: '<span class="infoTemplateContentRowLabel">Date: </span>' +
          '<span class="infoTemplateContentRowItem">${requestdate:DateFormat}</span><br><span class="infoTemplateContentRowLabel">Phone: </span>' +
          '<span class="infoTemplateContentRowItem">${phone:formatPhoneNumber}</span><br><span class="infoTemplateContentRowLabel">Name: </span>' +
          '<span class="infoTemplateContentRowItem">${name}</span><br><span class="infoTemplateContentRowLabel">Severity: </span>' +
          '<span class="infoTemplateContentRowItem">${severity:severityDomainLookup}</span><br><span class="infoTemplateContentRowLabel">Type: </span>' +
          '<span class="infoTemplateContentRowItem">${requesttype:requestTypeDomainLookup}</span><br><span class="infoTemplateContentRowLabel">Comments: </span>' +
          '<span class="infoTemplateContentRowItem">${comment}</span>'
excerpt 2:
// initialize the map and add the feature layer
  // and initialize map widgets
  var initMap = function() {
    app.map = BootstrapMap.create('map', config.mapOptions);
    app.citizenRequestLayer = new FeatureLayer(config.citizenRequestLayerUrl, {
      mode: FeatureLayer.MODE_ONEDEMAND,
      infoTemplate: new InfoTemplate(config.infoTemplate),
      outFields: ['*']
    app.map.addLayer(app.citizenRequestLayer);
RobertScheitlin__GISP
Chris,
The changes go in the main.js
define([
  'dojo/query',
  'dojo/dom',
  'dojo/dom-class',
  'dojo/dom-style',
  'dojo/dom-attr',
  'esri/config',
  'esri/layers/FeatureLayer',
  'esri/InfoTemplate',
  'esri/graphic',
  'esri/dijit/Geocoder',
  'esri/dijit/LocateButton',
  'esri/dijit/Legend',
  'esri/tasks/GeometryService',
  'esri/geometry/Extent',
  'esri/layers/ArcGISDynamicMapServiceLayer',
  'esri/layers/ArcGISTiledMapServiceLayer',
  'bootstrap-map-js/js/bootstrapmap',
  'dojo-bootstrap/Collapse',
  'dojo-bootstrap/Dropdown',
  'dojo-bootstrap/Modal',
  'dojo-bootstrap/Alert',
  'dojo/domReady!'
], function(
  query, dom, domClass, domStyle, domAttr,
  esriConfig, FeatureLayer, InfoTemplate, Graphic, Geocoder, LocateButton, Legend, GeometryService,
  Extent, ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer,
  BootstrapMap
  'use strict';
  /* The proxy comes before all references to web services */
      /* Files required for security are proxy.config, web.config and proxy.ashx
      - set security in Manager to Private, available to selected users and select Allow access to all users who are logged in
      (Roles are not required)
      The proxy section is defined on the ESRI sample. I have included it as
      part of the documentation that reads that the measuring will not work.
      I thought that might be important.
      // Proxy Definition Begin
      //identify proxy page to use if the toJson payload to the geometry service is greater than 2000 characters.
      //If this null or not available the project and lengths operation will not work.
      // Otherwise it will do a http post to the proxy.
      esriConfig.defaults.io.proxyUrl = "proxy.ashx";
      esriConfig.defaults.io.alwaysUseProxy = false;
    // Proxy Definition End
    // declare geometry service
    esriConfig.defaults.geometryService = new GeometryService("http://maps.decaturil.gov/arcgis/rest/services/Utilities/Geometry/GeometryServer");
  //Chris's options
      "xmin": 777229.03,
      "ymin": 1133467.92,
      "xmax": 848340.14,
      "ymax": 1185634.58,
          "wkid": 3435
  // app configuration
  var config = {
    mapOptions: {
      logo: false,
    infoTemplate: {
  // app globals
  var app = {};
  app.collapseMenuToggleButton = dom.byId('collapseToggleButton');
  app.startEditAlert = dom.byId('startEditAlert');
  app.sidebar = dom.byId('sidebar');
  app.attributesModal = query('#attributesModal');
  app.requestTypeSelect = query('#attributesModal [name="requesttype"]')[0];
  // TODO: get these from the feature layer on load
  app.severityFieldDomainCodedValuesDict = {
    '0': 'General Nuisance',
    '1': 'Important To Resolve Soon',
    '2': 'Critical Issue'
  app.requestTypeFieldDomainCodedValuesDict = {
    '0': 'Abandoned Vehicle',
    '1': 'Animal Services',
    '2': 'Driveway Infraction',
    '3': 'Flooding',
    '4': 'Graffiti Removal',
    '5': 'Homeless Nuisance',
    '6': 'Illegal Dumping',
    '7': 'Parking Violation',
    '8': 'Plant/Tree Complaint',
    '9': 'Pothole Obstruction',
    '10': 'Roadway Danger',
    '11': 'Sidewalk Danger',
    '12': 'Streetlight Broken',
    '13': 'Street Sign Missing/Damaged',
    '14': 'Trash Removal',
    '15': 'Water Leak',
    '16': 'Yard Waste Removal'
  // NOTE: popup formatting functions must be globals
  window.severityDomainLookup = function (value, key, data){
    return app.severityFieldDomainCodedValuesDict[value];
  window.requestTypeDomainLookup = function (value, key, data){
    return app.requestTypeFieldDomainCodedValuesDict[value];
  window.formatPhoneNumber = function (value, key, data){
    return value ? '<a href=\'tel:' + value + '\'>' + value + '</a>' : '';
  // initialize the request type drop down
  var initAttributeForm = function() {
    var options = [];
    for (var key in app.requestTypeFieldDomainCodedValuesDict) {
      if (app.requestTypeFieldDomainCodedValuesDict.hasOwnProperty(key)) {
        options.push('<option value="' + key + '">' + app.requestTypeFieldDomainCodedValuesDict[key] + '</option>');
    app.requestTypeSelect.innerHTML = options.join('');
    var tiled = new ArcGISTiledMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
    app.map.addLayer(tiled);
        "opacity": 0.5
    app.map.addLayer(operationalLayer);
      outFields: ['*']
    app.geocoder = new Geocoder({
      map: app.map,
      autoComplete: true,
      arcgisGeocoder: {
        placeholder: 'Address or Location'
      'class': 'geocoder'
    }, 'geocoder');
    app.geocoder.startup();
    // Begin geolocate button
    // add geolocate button to find the location of the current user
    app.map.on("load", function () {
        app.locateButton = new LocateButton({
            map: app.map,
            highlightLocation: true,
            useTracking: true,
            enableHighAccuracy: true
        }, 'locateButton');
        app.locateButton.clearOnTrackingStop = true;
        app.locateButton.startup();
        app.locateButton.locate();
    // End geolocate button
    app.legend = new Legend({
      map: app.map,
      layerInfos: [{
        title: 'Street Signs and Supports',
        layer: app.citizenRequestLayer
    }, 'legend');
    app.legend.startup();
    // TODO: other widgets, etc
  // hide nav dropdown on mobile
  var hideDropdownNav = function(e) {
    if (query('.navbar-collapse.in').length > 0) {
      e.stopPropagation();
      app.collapseMenuToggleButton.click();
  // temporarily show alert when starting edits
  // and then start listening for a map click
  var startCaptureRequest = function(severity) {
    var listener;
    // NOTE: once user has clicked 'x' to dismiss
    // this alert, it will no longer show up
    domStyle.set(app.startEditAlert, 'display', '');
    setTimeout(function() {
      domStyle.set(app.startEditAlert, 'display', 'none');
    }, 3000);
    // save map point in app global and
    app.currentSeverity = severity;
    listener = app.map.on('click', function(e) {
      listener.remove();
      // show form to collect incident report
      app.currentGeometry = e.mapPoint;
      app.attributesModal.modal('show');
  var stopCaptureRequest = function() {
    app.currentSeverity = null;
    app.currentGeometry = null;
  // get attributes from form and submit
  var submitIncidentReport = function() {
    var attributes = {
      // TODO: not sure if this is needed
      requestreceived: null
    var currentDate = new Date();
    var graphic;
    if  (!app.currentSeverity || !app.currentGeometry) {
      return;
    graphic = new Graphic(app.currentGeometry);
    attributes.severity = parseInt(app.currentSeverity, 10);
    query('#attributesModal input, #attributesModal select, #attributesModal textarea').forEach(function (formInput) {
      attributes[formInput.name] = formInput.value;
    attributes.requesttype = parseInt(attributes.requesttype, 10);
    attributes.requestdate = Date.UTC(currentDate.getUTCFullYear(), currentDate.getUTCMonth(),
    currentDate.getUTCDate(), currentDate.getUTCHours(), currentDate.getUTCMinutes(),
    currentDate.getUTCSeconds(), 0);
    graphic.setAttributes(attributes);
    stopCaptureRequest();
    // console.log(attributes);
    app.citizenRequestLayer.applyEdits([graphic], null, null).then(function(response) {
      console.log(response);
  // wire up the DOM events
  var initEvents = function() {
    // listen for map clicks once severity is chosen
    query('.report-btn-group .dropdown-menu a').on('click', function(e) {
      e.preventDefault();
      startCaptureRequest(domAttr.get(e.target, 'data-value'));
    // TODO show the feedback modal
    query('a[href="#feedback"]').on('click', function(e) {
      e.preventDefault();
      query('#feedbackModal').modal('show');
    // hide drop down nav after clicking on a link
    query('.navbar-collapse a').on('click', function(e) {
      hideDropdownNav(e);
    // change the basemap
    query('#basemapDropdown a').on('click', function(e) {
      var basemapName = domAttr.get(e.target, 'data-name');
      if (basemapName && app.map) {
        app.map.setBasemap(basemapName);
    // toggle the sidebar
    query('#sidebarToggleButton').on('click', function(e) {
      // make sure sidebar is same height as the map
      if (app.map.height) {
        domStyle.set(app.sidebar, 'height', app.map.height + 'px');
      domClass.toggle(window.document.body, 'sidebar-open');
      hideDropdownNav(e);
    // submit or cancel request and hide modal
    query('#attributesModal .btn').on('click', function(e) {
      var target = e.target;
      if (target.innerText === 'Submit') {
        submitIncidentReport();
      app.attributesModal.modal('hide');
    query('#feedbackModal .btn').on('click', function(e) {
      // NOTE: this is not implemented in sample app
      query('#feedbackModal').modal('hide');
    // clear current edit session globals
    app.attributesModal.on('hidden.bs.modal', stopCaptureRequest);
  // finally, start up the app!
  initAttributeForm();
  initMap();
  initEvents();
  return app;
Chris,
define([
  'dojo/query',
  'dojo/dom',
  'dojo/dom-class',
  'dojo/dom-style',
  'dojo/dom-attr',
  'esri/config',
  'esri/graphic',
  'dojo/domReady!'
], function(
  BootstrapMap
  'use strict';
  //Chris's options
      "xmin": 777229.03,
      "ymin": 1133467.92,
      "xmax": 848340.14,
      "ymax": 1185634.58,
          "wkid": 3435
  var config = {
    mapOptions: {
      logo: false,
    infoTemplate: {
  // app globals
  var app = {};
    '3': 'Flooding',
    '15': 'Water Leak',
    var options = [];
        "opacity": 0.5
      outFields: ['*']
      map: app.map,
      autoComplete: true,
      arcgisGeocoder: {
      'class': 'geocoder'
    }, 'geocoder');
            map: app.map,
            useTracking: true,
        }, 'locateButton');
      map: app.map,
      layerInfos: [{
    }, 'legend');
    var listener;
    }, 3000);
      listener.remove();
    var attributes = {
    var graphic;
      return;
      e.preventDefault();
      e.preventDefault();
      hideDropdownNav(e);
      hideDropdownNav(e);
  initMap();
  initEvents();
  return app;
ChrisSergent
Perfect! Thank you!
