How to transfer a query from R. Calculator to ArcPy
7739
16
03-16-2015 07:22 AM
KONPETROV
I am using ArcGis 10.2. I have 3 classified rasters and i want to use the following query from r. calculator:
                  (rclslope>=45) & (rclmosaic>=2000) & (rclfocal>15) to arc.py
how can i write it?
Is it better to use local - combine tool with arc.py to do it?
Thank you very much.
DarrenWiens2
You could ​use the Con tool (see this page for relevant examples):
Con(("rclslope">=45)&("rclmosaic">=2000)&("rclfocal">15),1)
This returns a raster with pixel value = 1 which meets the criteria. If you're looking for a way to spatially query pixel values in ArcGIS, that doesn't exist to my knowledge.
KONPETROV
thanks a lot Mr. Darren Wiens. But i need a little more help if you can. The entire code should seem like;
DarrenWiens2
There are lots of arcpy examples using Con here​ - scroll to the bottom.
KONPETROV
So we mean something like that?
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
outCon = Con(("rclslope">=45)&("rclmosaic">=2000)&("rclfocal">15),1)
outCon.save("C:/sapyexamples/output/outcon")
KONPETROV
Because with that i get an error
DanPatterson_Retired
well the error would help and you should have spaces between the grid names and the operands and perhaps it can't find the grids (assumed since there are no file extensions)   And the big one is that you didn't make raster objects from you grid names.  and please tell me that you have a path called c:/saexamples to test it in.
inRas1 = Raster("inRaster"
inRaster is inside the path
inRas1 is a Raster object which is needed by the Con statement
DarrenWiens2
Agreed, mostly. What's this about spaces? AFAIK, they are irrelevant.
KONPETROV
Mr. Patterson i think i cannot understand you very well. I am still new in programming.
DarrenWiens2
Please post the error.
