How to transfer a query from R. Calculator to ArcPy
7808
16
03-16-2015 07:22 AM
KONPETROV
I am using ArcGis 10.2. I have 3 classified rasters and i want to use the following query from r. calculator:
                  (rclslope>=45) & (rclmosaic>=2000) & (rclfocal>15) to arc.py
how can i write it?
Is it better to use local - combine tool with arc.py to do it?
Thank you very much.
KONPETROV
Runtime error
  File "<string>", line 5, in <module>
  File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\sa\Functions.py", line 244, in Con
    where_clause)
  File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\sa\Utils.py", line 47, in swapper
    result = wrapper(*args, **kwargs)
  File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\sa\Functions.py", line 228, in Wrapper
    ["IfThen", in_conditional_raster, in_true_raster_or_constant])
RuntimeError: ERROR 999998: Unexpected Error.
This keeps appearing with the following code:
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
outCon = Con( ( "rclslope" >= 45 ) & ( "rclmosaic" >= 2000 ) & ( "rclfocal" > 15 ), 1 )
outCon.save("C:/sapyexamples/output/outCon")
DanPatterson_Retired
outCon = Con( ( Raster("rclslope") >= 45 ) & ( Raster("rclmosaic") >= 2000 ) & ( Raster("rclfocal") > 15 ), 1, 0 )
KONPETROV
Mr. Wiens Unfortunately yes they exist!! Grid format also!! For God.
Mr. Patterson so finally we have that:
import arcpy
env.workspace = "c:/sapyexamples/data"
outCon.save("c:/sapyexamples/output/outCon")
Right?
When i am loading it i am getting a raster with an attribute table with only one row and one colour all over the layer. No classes not anything. Why is that?
If i write the same proccedure in Raster Calculator (rclslope>=45) & (rclmosaic>=2000) & (rclfocal>15)
i ll get the result i want, here what am i doing wrong.
the raster calculator is different that a script that uses rasters in a script. If the script gives you a result and you have a table, then you will have one of 2 values... 1 (where the condition is met) or 0 (where the condition is not met)  A smart approach would be to use the Con tool in arctoolbox then if that works, go to the Results window and use that as the snippet for your code see my blog for examples related to Results and other programming tips
KONPETROV
Thank you very much sir, i ll try it
KONPETROV
Thank you both on of the problems was that : rclslope >= 45 !! e.g. rclslope it's already reclassified, so i just had to put slope. The other problem was something that had to do with my computer and Gis 10.2. so i put my computer on an earlier state to solve it. The code is working perfectly now with your corrections, that thing with spaces is very tricky.
glad it is resolved ... tips for the future...never assume your inputs are correct, start from the beginning...always build incrementally, don't try to do a complex statement all at once, errors will be readily identified  good luck​
