Hi ,
The QML API can be used to edit features within an offline geodatabase and sync back to the service.When download a local geodatabase from the service, can I download only geometry areas (with poligon drawing ) which I draw from the map and then to create,delete or update features in local then send to server more fast. Is it posible in QML API ? or how can I solve the problem for more fast dowloading local geodatabse (for ex: download only drawing poligon part of the maps geodatabase not complete geodatabase).
Can I solve with this code below?
onClicked: {
generateGeodatabaseParameters.initialize(serviceInfoTask.featureServiceInfo);
//Can I solve with this red code below?
generateGeodatabaseParameters.extent = mainMap.extent;//instead of mainMap.extent use geometry(draw polygon)
generateGeodatabaseParameters.returnAttachments = false;
statusText.text = "Starting generate geodatabase task";
geodatabaseSyncTask.generateGeodatabase(generateGeodatabaseParameters, gdbPath);
Thanks.
