For Remote Desktop - Disable Frame Rate - Disable Animation
4379
03-12-2015 06:25 AM
MarvinKalani
is it possible to configure the MapView to a defined maximum frame rate and disable all animations.
I would like to use the map in a remote desktop environment and currently it is unusable.
Best regards,
Marvin Kalani
MarvinKalani
With Resharper I see in the ViewBase.cs :
internal static readonly TimeSpan m_ZoomDuration = TimeSpan.FromMilliseconds(500.0);
As you can see I am not able to set this from the outside.
Usually I can set the desired Framerate via :
Timeline.DesiredFrameRateProperty.OverrideMetadata(typeof(Timeline), new FrameworkPropertyMetadata { DefaultValue = 30 });
Timeline.DesiredFrameRateProperty Field (System.Windows.Media.Animation)
But it seems to be overwritten somewhere so that the animations consume too much network traffic.
Can you please give me a solution?
