InfoWindow TabContainer & ContentPane Issue
3979
03-10-2015 01:43 PM
by Anonymous User
Not applicable
I am trying to programatically create a TabContainer in an InfoWindow and populate it with ContentPane's based on an identify task. The first issue I am having is the TabContainer is not embedding the slider and Menu correctly- they span the enitre top portion of the TabContainer. The second issue is the first contentPane is not showing its content, only the tab. If i click on another contentpane the content is displayed.
Do i need to resize the tabcontainer?
the portion of my code:
function addToMap(idResults, event) {
   if (idResults < 1) {
  map.infoWindow.setContent("No Visible Layer Found - Turn on a Layer and click it to Identify");
   } else {
  tc = new TabContainer({
  style: "height: 100%; width: 100%;",
  useMenu: false,
  useSlider: true
   }, domConstruct.create("div"));
   for (var i = 0, il = idResults.length; i < il; i++) {
   var idResult = idResults[i];
   var featureAttributes = idResults[i].feature.attributes;
   var contentAttributes = [];
   for (var attr in featureAttributes) {
  contentAttributes.push("<b>" + attr + " </b>" + featureAttributes[attr] + "<br/>");
  cp = new ContentPane({
  title: idResults[i].layerName,
  content: contentAttributes.join("")
  tc.addChild(cp);
  console.log(cp);
  map.infoWindow.setContent(tc.domNode);
  tc.startup();
KenBuja
MVP Esteemed Contributor
When I create ContentPanes in TabContainers, I use the startup method on the ContentPane and at the end, resize the TabContainer. This code adds a dGrid to a ContentPane for each set of results and is used on this page: NCCOS Data Viewer
function populateTC(results, evt) {
        try {
            if (dijit.byId('tabs').hasChildren) {
                dijit.byId('tabs').destroyDescendants();
            if (results.length === 0) {
                console.log('Nothing found.');
                return;
            var combineResults = {};
            for (var i = 0, len = results.length; i < len; i++) {
                var result = results;
                var lyrName = result.layerName.replace(' ', '');
                if (combineResults.hasOwnProperty(lyrName)) {
                    combineResults[lyrName].push(result);
                else {
                    combineResults[lyrName] = [result];
            for (result in combineResults) {
                if (combineResults.hasOwnProperty(result)) {
                    var columns = buildColumns(combineResults[result][0].feature);
                    var features = [];
                    for (i = 0, len = combineResults[result].length; i < len; i++) {
                        features.push(combineResults[result].feature);
                    var data = array.map(features, function (feature) {
                        return lang.clone(feature.attributes);
                    var dataGrid = new (declare([Grid, Selection, DijitRegistry, ColumnHider]))({
                        id: "dgrid_" + combineResults[result][0].layerId,
                        bufferRows: Infinity,
                        columns: columns,
                        selectionMode: "single",
                        "class": "resultsGrid"
                    var gridWidth = "width: " + String(columns.length * 100) + "px";
                    dataGrid.addCssRule("#" + dataGrid.id, gridWidth);
                    dataGrid.on(".dgrid-row:click", gridSelect);
                    dataGrid.on("show", function () {
                        dataGrid.resize();
                    dataGrid.on(mouseUtil.enterRow, gridEnter);
                    dataGrid.on(mouseUtil.leaveRow, function () {
                        map.graphics.clear();
                    var plural = "";
                    if (combineResults[result].length !== 1) { plural = "s"; }
                    var cp = new dijit.layout.ContentPane({
                        //content: "<strong>" + combineResults[result][0].layerName + "</strong> (" + combineResults[result].length + " feature" + plural + ")",
                        content: combineResults[result].length + " feature" + plural,
                        //content: dataGrid,
                        title: combineResults[result][0].layerName,
                        style: "overflow: auto"
                    }).placeAt(dijit.byId('tabs'));
                    cp.addChild(dataGrid);
                    cp.startup();
                    dataGrid.renderArray(data);
            tc.startup();
            tc.resize();
            map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
        catch (e) { console.log(e.message); }
KenBuja
        try {
                return;
                else {
                    var features = [];
                        columns: columns,
                        dataGrid.resize();
                    var plural = "";
                    cp.startup();
            tc.startup();
            tc.resize();
by Anonymous User
Not applicable
Thanks, I ended up finding a solution by simply setting the style of the TabContainer to slightly smaller than the infoWindow, then resizing the tc at the end. I will probably end up using the dgrid later so I will reference your code.
