with programmatically element of javascript
5017
03-08-2015 12:52 AM
yousofothman
hi
every body
i want example that add shape file to the map
but all element on page must be created programmatically with dojo
i try this:
 _addShapeFile: function (tool, toolbar, panelClass) {
            var ShapeFileDiv = toolbar.createTool(tool, panelClass);
            domStyle.set(ShapeFileDiv, {
                "height": "100%",
                "width": "100%"
            //var newDiv1 = document.createElement("div");
            //document.getElementById("newDiv1").appendChild(ShapeFileDiv);
            ////newDiv1.appendChild(ShapeFileDiv);
            var file = document.createElement("INPUT");
            file.setAttribute("type", "file");
            var uploadForm = dojo.place("<form> Add shapefile as .zip file </form>", ShapeFileDiv);
            domConstruct.place(file, uploadForm);
            var ShapeFilebutton = domConstruct.create("button", {
                innerHTML: "Add FIle ",
                className: "button",
                type: "button",
                style: { color: "red" }
            }, domConstruct.create("div", {
                "class": "button11"
this code create button and upload file on form but i could not add the uploaded file to the map
any help please
Tags (1)
RobertScheitlin__GISP
Yousof,
   Then you need to look at JS Shapefile library like this one:
mbostock/shapefile · GitHub
Yousof,
   See this sample: Add shapefile | ArcGIS API for JavaScript
yousofothman
thank you for replying but this sample create all element in html where i want it programmatically
Yousof,
yousofothman
thank you
