Creating several buffers in a loop fails silently
5236
03-06-2015 05:35 AM
MichalWysokinski
I'm experiencing a very weird behaviour when I try to create either several single or multiple buffers. I have a python script which conducts geoprocessing (creating buffers is one of the first steps) on a series (about 100) of feature classes (consisting of a single point) in a loop.
My problem is that when I run this script always up to 50-70% of buffers operations fail. After the script is complete and I run it again I get a similar behavior but some of the data, for which the calculations previously failed, is calculated correctly. If I run it enough number of times all calculations will complete succesfully.
One interesting thing is that if I try to recalculate buffers in the same process (after failing I immediately retry) it will infinitely fail. I need to finish one process and start another one in order to have a chance that another try will succeed.
Another interesting and most painful thing is that the operation itself does not fail and does not give any errors. Both Buffer_analysis and MultipleRingBuffer_analysis finish without errors, but the output layer is not created or is empty.
In each iteration I set a different workspace and scratchworkspace (which is a file gdb), so it is not a problem with temp files being overwritten (unless there are some temp files created behind the scene). I also have access to the files (both for reading and writing) at all times. Each time I set several env parameters (scratchWorkspace, workspace, snapRaster, cellSize, overwriteOutput, addOutputsToMap) and save output to different catalogs.
I also don't do anything fancy in the code, I create buffers using either:
arcpy.MultipleRingBuffer_analysis(r"path_to_fc", r"output_path_for_shp", [2, 10.5, 18.3], 'Kilometers', 'fieldname')
At first I thought that maybe MultipleRingBuffer_analysis, which is just a python script, does something under the hood, so I reimplemented it as a loop creating single buffers and later unify and dissolve them. This is the part that fails:
for dist in [2, 10.5, 18.3]:
    arcpy.Buffer_analysis(r"path_to_fc.shp", r"output_path_{}.shp".format(dist), "{} kilometers".format(dist), "FULL", "ROUND")
My configuration is following:
- Win 7 64-bit
- XEON E5649 6 cores
- 8 GB RAM
- > 100 GB disk space
TomSellsted
Michal,
Had you considered using a cursor and maybe buffering the point geometry to create your buffers?  Something like:
import arcpy
ofc ="path_to_output_fc"
outcur = arcpy.InsertCursor(ofc)
fc = "path_input_point_fc"
cursor = arcpy.SearchCursor(fc)
for row in cursor:
    pt = row.shape
    ptgeo = arcpy.PointGeometry(pt)
    ptbuff1 = ptgeo.buffer(distance1)
    orow = outcur.newRow()
    orow.setValue("shape",ptbuff1)
    outcur.insertRow(orow)
    ptbuff2 = ptgeo.buffer(distance2)
    orow.setValue("shape",ptbuff2)
    ptbuff3 = ptgeo.buffer(distance3)
    orow.setValue("shape",ptbuff3)
del outcur, orow, row, cursor
Regards,
Tom
DarrenWiens2
If you post your entire script, we may have a better chance of diagnosing the problem.
