arcpy - Sum fields from ListFields - RuntimeError: A column was specified that does not exist?
4295
03-06-2015 05:28 AM
DavorinBajic1
Does someone can help?
import arcpy, os, string
fc
= "D:\\path\\test.shp"
fieldNameList
fields
= arcpy.ListFields(fc, "*")
for field in fields:
if field.type in ("Double", "Integer", "Single", "SmallInteger"):
  fieldNameList
.append(field.name)
  fn
= "'" + "', '".join(fieldNameList) + "'"
print(fn)
with arcpy.da.UpdateCursor(fc, [fn]) as cursor:
for row in cursor:
  row
[4] = row[0] + row[1] + row[2] + row[3]
  cursor
.updateRow(row)
ERROR - RESULT
'tt', 'ff', 'vv', 'rr', 'update'
File "E:\path\test.py", line 17, in <module>
for row in cursor:
RuntimeError: A column was specified that does not exist.
Does anyone have a suggestion on how to otherwise solve the problem ... The need to automatically generate all the columns from the table, the calculation of the sum, the results are updated in the new column?
thanks in advance
PS I am an absolute beginner in python programming
Tags (1)
DavorinBajic1
I solved the problem...
fc = "D:\\path\\test.shp"
fieldNameList = []
fields = arcpy.ListFields(fc, "*")
               fieldNameList.append(field.name)
     with arcpy.da.UpdateCursor(fc, fieldNameList) as cursor:
          for row in cursor:
               row[4] = row[0] + row[1] + row[2] + row[3]
          cursor.updateRow(row)
DavorinBajic1
fieldNameList = []
          for row in cursor:
