OLE DB Connection won't save password
3982
03-02-2015 07:25 AM
LukeSnyder
Hi All
I've created an OLE DB connection to an iSeries application server (IBM DB2 for i5/OS IBMDA400 OLE DB Provider).
No matter the password configuration I use (Blank Password / Password Saving), when I access the published map on another user's system, it doesn't access the information correctly.
Scenarios
  • Blank Password checked: Map opens without prompt, acts as if all data is accessible, but doesn't display the joined table data
  • Saved Password checked and password entered: Map opens with Server password window prompt. If entered, it displays correctly.
I want the information accessible without users being asked for a password.
Is this something I need to address in my Windows Credential Manager?
LukeSnyder
Hi Kaia
Yes. I was accessing the connection with the IP address and not as a registered User. Originally it was for example
U: 10.0.1.1 / P: xxxxx. (this was done per the server administrators). After much wasted time, I asked to create a general user U: BobbyS / P: xxxxx. That connection carries through with the published maps so the network users can access the data.
The password now stays connected to the credentials.
KaiaSele
I know it is 3 years after you posted this question, but did you ever figure this out? I am having the same issue now.
Thanks!
LukeSnyder
Hi Kaia
