How to handle port changes between Load Balancer and WebAdaptor/ArcServer
7556
9
02-27-2015 05:18 PM
JasonTipton
Philip Heede How do you authenticate behind an F5/proxy that is changing the port. The F5 is forwarding traffic from 443 to 6080. When I add the webadaptor, the authentication tries to hit against the port 6080 instead of 443 like all other traffic...
It seams like 80% of links return /arcgis/rest.... ,but the authentication piece returns the full url http://server:6080/arcgis/.... which obviously won't work.
Message was edited by: Jason Tipton
pheede-esri
Jason Tipton‌ Ensure you're following the guidance at Using a reverse proxy server with ArcGIS Server—Documentation | ArcGIS for Server  for setting the required HTTP headers and optionally the WebContextUrl if appropriate.
Cheers,
Philip
JasonTipton
Here's a little better example of what's going on. Traffic is coming through a reverse proxy on port 443. It is being forwarded on to a load balancer using port 443. The load balancer is doing SSL offloading so it is forwarding unencrypted traffic on to the Web Adaptor now at port 80 (It was 6080, but now 80). The WebAdaptor then forwards traffic to the ArcServer on 6080.
Browser  <= 443 =>  Rev Proxy  <= 443 => F5  <= 80 => Web Adaptor <= 6080 => ArcServer
I tried setting the WebContextUrl in the admin to httpS://gisserver.xyz.com/arcgis . It didn't seem to change anything. I'm not sure if it is the X-Forwarded Host Headers either, b/c the url's that it is returning have always been the correct url, just http and wrong ports (http://gisserver.xyz.com/arcgis) instead of http://servername.xyz.com/arcgis. I haven't checked the IIS logs, but shouldn't I be able to find those headers in the log?
Again, it seems like most urls are relative and start with "/arcgis/....". It's just the admin/login piece that returns the full url path "http://gisserver.xyz.com/arcgis/....". Not sure why it even needs to return the full url.
JasonTipton
This question is similar: Reverse Proxy - Web Adaptor - ArcGIS Server configuration . The problem here was changing the url without creating a new webadaptor. It seems that the WebContextURL is ignored if you are using a WebAdaptor. Jeff Smith suggested removing the webadaptor fo the WebcontextURL to work or creating a new WebAdaptor.
This issue was logged as an enhancement. What is the status of this? and is my WebContextURL being ignored?
pheede-esri
In order to troubleshoot and get a status on any logged enhancement requests, please contact Tech Support and they will be able to assist with both things.
Cheers,
Philip
JasonTipton
Already done.... so.....the WebcontextURL. Is it ignored if you are using a WebAdaptor?
JasonTipton
The feeling I am getting from responses and from the traditional support route, is that SSL offloading is not supported, b/c that is what is causing this issue.
Here is an ESRI doc mentioning the benefits of using hardware level SSL offloading.http://resources.arcgis.com/en/communities/enterprise-gis/01n20000002n000000.htm
JeffSmith
Jason, the information you have heard from Support is accurate: the SSL offloading is not supported.
Regarding the WebContextUrl, I'm not sure what version of ArcGIS Server and Web Adaptor you are using but in version 10.3, you shouldn't need it.  If the X-Forwarded-Host header is included from the F5 load balancer to the web adaptor, the fqdn for the Login url should match that header.  The format of the header should be fqdn/webadaptor (ex server.esri.com/arcgis).  The WebContextUrl is only necessary if you remove the web adaptor and redirect directly to the Server from the F5 load balancer.
JasonTipton
I'm on 10.2.2. All the WebcontextURL seemed to do is to mess things up.  So, at 10.3, would that X-Forwarded-Host header honor the httpS (and port number) or just server name?
Say my site is:
https://myGISServer.com
and it goes throughh http:////gis/arcgis locally, would the login url be
http://myGISServer.com/arcgis/rest/login   OR
httpS://myGISServer.com/arcgis/rest/login
JeffSmith
No, in 10.3 it will be the same as how you are seeing it in 10.2.2.  The protocol defined in the WebContextUrl is not used.  In other words, if your F5 load balancer is doing SSL offloading, the Login url you see on the Rest page will be HTTP, not HTTPS.  If you configure the F5 load balancer to redirect to the web adaptor over HTTPS, the Login url on the Rest page will be HTTPS.
I want to make a correction from my last post.  The 'X-Forwarded-Host' header used from your F5 load balancer just needs to be the fqdn, not fqdn/webadaptor.
