Authentication problem
6266
02-24-2015 12:36 AM
JacobSaugmann
Hi
Im using leaflet and Esri leaflet plugin, our ArcGIS server uses Windows Authentication.
I my javascript i get a token from the server and passes the token to the featureLayer request, my problem is:
the response from the server is Access denied but when i copy/paste the request URL in a different browser window the server returns features.
What can be wrong?
Copy paste URL to another browser window:
Jacob
JacobSaugmann
I figured out what is wrong but not how to fix it
When I am calling the featurelayer even do I have a token present in the request, the endpoint still requires windows authentication. (when copying the link to a different browser then I’m prompted with a login dialog )
So how can I via ESRI-leaflet make a windows authentication in my calls to the endpoint?
SachinKanaujia
Would you mind showing with your code snippet, how you are making the calls right now?
Here is how the Authentications are done
ArcGIS Online Authentication | ArcGIS for Developers
JacobSaugmann
Hi Sachin
Yes the code looks like this
 L.esri.get("http://myserver/webadapter/tokens/generateToken", {
username: "username",
password: "password,
f:"json",
expiration: 86400,
client: "requestip",
referer: window.location.origin
}, function (error, response) {
token = response.token;
if (token) {
   LoadAgsLayers();
} else {
   console.log("Ingen token blev hentet");
this code returns a token
Then i try to get the layer with
var lukkeKort = L.esri.featureLayer("http://myserver/webadapter/rest/services/Varme/varme1/MapServer/27",
token: token,
useCors: true
lukkeKort.addTo(map);
This code passes a link with the token, but gets  "access denied,"
We created another webadaptor using basic authentication, now i need to add authentication informations in the header before the request is made, but i can't figure out how to setRequestHeader on the request.
When i copy paste the link to a different browser and login, then the service returns features.
JacobSaugmann
Just to show it works when the basic authentication header is added
