Raster Calculator - using the conditional options
6366
6
02-23-2015 11:17 AM
lauriehogan
I'd like to use the raster calculator to convert 0 values in the raster to 0.0001.
I was trying to use the syntax below
CON ("raster1" == 0, 0.001, "raster1")
Based on 39974 - Change a particular value of a raster dataset to zero without changing the other values
1. In ArcMap, navigate to ArcToolbox > Spatial Analyst Tools > Map Algebra and open the Raster Calculator.
2. In the Raster Calculator, input the following syntax:
Con("InRaster" == -9999, 0 , "InRaster")
All I get is errors in 10.3 (see attachment).  I'm not a python user, so could really use help with this syntax.
Thanks for the help!
Tags (1)
DanPatterson_Retired
That is for older versions, check the current help files for Con
lauriehogan
Thanks for pointing me to the area to check out...  I had tried to find that source, but no luck.
I'll give these syntax examples a try.
A good link for bookmarking is the top of the Arctoolbox tree as in this link...
lauriehogan
Con ("raster1", 0.0001, "raster1" == 0) was next syntax in raster caculator didnt' work either.
and
Con ("raster" == 0 , 0.0001, "raster1")
Con("elev_967_1","elev_967_1", 0.0001, "VALUE>0.0001")
Con("VALUE < 0.001","elev_967_1", 0.0001)
None of these worked.
JakeSkinner
Esri Esteemed Contributor
Hi Laurie,
How are you adding the raster name to the statement?  Are you double-clicking from the 'Layers and Variables' box within this tool?  The error is indicating it cannot find the raster.
lauriehogan
Jake,
Yes, I was double clicking into the  Layers and variables in the  dialog box...  (These are not on my c: drive, but these layers are in arcmap currently.
Laurie
