ArcSDE / SQL Server compatibility level
9473
6
02-22-2015 04:43 AM
PaulLohr
I did not find anything in the ArcSDE documentation referring to SQL Server's compatibility level. Not too much mentioned on the forums either.
Can anyone come up with a scenario where the compatibility level of SQL Server should be set to a version earlier than the instance that is installed? Perhaps an old application that will not be updated?
Thanks for any help,
Paul Lohr
Paul Lohr
Lohr Geospatial Services, Inc.
JayantaPoddar
Hi Paul,
Check this technical article if it is helpful.
Jay
Think Location
AsrujitSengupta
ALTER DATABASE Compatibility Level (Transact-SQL)
The above link should provide you with information related to the importance and difference between the different SQL Server Compatibility level.
From ArcSDE point of view, as per my understanding, as long as the version of the database is supported, it should not be a problem. However maybe someone else may have some more info on this......
JoshuaBixby
MVP Esteemed Contributor
Given that ArcSDE documentation doesn't address SQL Server's compatibility level, I would argue there is an implicit requirement that ArcSDE be installed in SQL Server databases with the default setting.
BillFox
MVP Notable Contributor
Hi Paul,
Did you receive any further information about ESRI/SQL Server compatibility levels?
With 10.4.x not supporting SQL Server 2008 R2, has anyone seen ESRI documentation on SQL Server compatibility levels?
2016     130
2014     120
2012     110
2008 R2     105
2008     100
2005     90
2000     80
-Bill
Asrujit SenGuptaSanket
BillFox
Reference ESRI documentation v10.4:
Upgrade an enterprise geodatabase in SQL Server
Upgrade an enterprise geodatabase in SQL Server—Help | ArcGIS for Desktop
"Tip:
If you are unsure of the database compatibility level of your SQL Server database, check the database properties from Microsoft SQL Server Management Studio. If your database compatibility level is 80, you must update your database compatibility level. See SQL Server documentation for instructions."
But it does not indicate which level we must set it to for 10.4.1, 10.3.1. etc.
Asrujit SenGupta‌ SButala-esristaff
BillFox
See the "Supported Compatibility Level Values" column below.
Example: The SQL Server 2014 geodatabase can be set to 100 or 110 or 120 and ESRI is good to go.
Reference Microsoft SQL Server documentation:
database_name
Is the name of the database to be modified.
COMPATIBILITY_LEVEL { 130 | 120 | 110 | 100 | 90 | 80 }
Is the version of SQL Server with which the database is to be made compatible. The following compatibility level values can be configured:
ProductDatabase Engine VersionCompatibility Level DesignationSupported Compatibility Level Values
SQL Server 201613130130, 120, 110, 100
SQL Database12120130, 120, 110, 100
SQL Server 201412120120, 110, 100
SQL Server 201211110110, 100, 90
SQL Server 2008 R210.5105100, 90, 80
SQL Server 200810100100, 90, 80
SQL Server 200599090, 80
SQL Server 200088080
-Bill
Thank you: asengupta-esristaffSButala-esristaff
