License levels for DBMS use in Arc
4344
02-20-2015 09:48 AM
TomHoober
I am a basic level user. Can I use any DBMS types with ESRI? I did find out that to use postgres I had to have at least a standard. I am assuming across the board ESRI has entry to this functionality at the standard... more expensive level.
Tags (3)
XanderBakker
Esri Esteemed Contributor
Depending on the usage you will probably need a Standard license (at least for editing an enterprise gdb). More details on what you can do with each license can be found here:
http://www.esri.com/~/media/Files/Pdfs/library/brochures/pdfs/arcgis1021-desktop-functionality-matri...
