In the Layer Properties go to the Symbology tab then choose the Graduated Colors option. Select your field containing the values, set 10 classes then click on the Classify button. You can then click on any of the colors and change it to match your desired symbol.
EDIT - you will actually need 14 classes and you will need to change the Range values to match your example.
