ArcGISTiledMapServiceLayer and WMTSLayer
4751
02-16-2015 05:31 AM
UrsRichard
I'm using an ArcGISTiledMapServiceLayer as baselayer in a ESRI API for JavaScript project. As a second layer I'm trying to add a WMTS Layer. Unfortunately the WMTS Layer will not be shown. If I use the same WMTS layer as baselayer it works fine. The ArcGISTiledMapServiceLayer and the WMTS Layer uses the same spatial reference but have different LODs/TileMatrixSets. Is it possible to use a WMTS Layer together with a ArcGISTiledMapServiceLayer?
TimWitt2
Hey Urs,
what code are you using to add the WMTS layer?
Tim
UrsRichard
<script>
            var map;
            require(["esri/map", "esri/layers/WMTSLayer", "dojo/domReady!"], function(Map, WMTSLayer) {
                var extent = new esri.geometry.Extent(595171.7678435356, 200875.0317500635, 702328.2321564644, 294124.9682499365, new esri.SpatialReference({
                    "wkid": 21781
                map = new Map("map", {
                    //basemap: "topo",
                    //center: [7.537513, 47.208331], // longitude, latitude
                    // zoom: 13
                    extent: extent
                esri.config.defaults.io.proxyUrl = "./proxy/PHP/proxy.php";
                // esriConfig.defaults.io.alwaysUseProxy = false;
                var layerinfo = new esri.layers.WMTSLayerInfo({
                    identifier: 'ch.swisstopo.pixelkarte-grau'
                var options = {
                    layerInfo: layerinfo
                var wmts = new WMTSLayer("http://wmts.geo.admin.ch", options);
                var luftbild = new esri.layers.ArcGISTiledMapServiceLayer("https://quality.ag.ch/geoportal/rest/services/base_ortho2013_full/MapServer", {
                var giselan = new esri.layers.ArcGISDynamicMapServiceLayer("https://www.ag.ch/geoportal/rest/services/lwag_giselan_app/MapServer", {
                map.on("load", function(map){
                    //use as breakpoint for layer loaded
                    var i = 10;
                map.addLayer(luftbild);
                map.addLayer(wmts);
                // map.addLayer(giselan);
        </script>
YueWu1
by Esri Regular Contributor
Hi Urs,
Here is an sample to show you how to load WMTSLayer and ArcGISTiledMapServiceLayer together on mapview.
JS Bin - Collaborative JavaScript Debugging
In order to “bypass” proxy to execute a WMTSLayerGetCapbilities request, we need to
  1. Redefine the WMTSLayer’s Tileinfo based on your ArcGISTiledMapServiceLayer LOD, dpi an so on…
  2. Create a new WMTSLayer resourceInfo
Hope this can help.
