Is it possible to change defaults of service editor dialog?
4076
02-16-2015 10:43 AM
BrandonKeinath1
Is it possible to edit the default parameters and settings that are part of the service editor dialog?  When we publish services there are some settings we change each time and it would be great to modify the defaults.  I'd also be interested if anyone has found a way to add custom business logic into the "analyze" portion of service creation.  I can post an example of something if that would be helpful to the discussion.
DanielGarcia
Hi Brandon,
This is the same question... Disable KML option support by Default on Map Service
...but... there is no answer...
Regards
Dani
