Disable KML option support by Default on Map Service
6479
12-05-2013 05:19 AM
MeleKoneya
When publishing a map service KML support is enabled by default.
Is there a way to set the KML support for a Map Service to off by default so that each time a Map Service is published we don't have to uncheck this option?
Mele
DanielGarcia
Anybody answered your question? I'm also interested. I need to specify some others default options during publish map operation.
Dani
MeleKoneya
Dani,
No,  I have not received any feedback or found a solution to this.    I do believe that in 10.2.2 the settings for a service are set,  so that if you have KML turned off,  when it is overwritten with a re-publish,  the settings are kept.
That does not help with new services though and the defaults for them.
Mele
DanielGarcia
Thank you Mele,
I think that should be exist a ArcGIS Server o desktop property file to specify default options when user publish new maps.
don´t you think?
Regards,
Dani
