cursor error
5228
6
02-15-2015 11:49 AM
DEAF_PROBERT_68
Honored Contributor
On page 169 of the Programming ArcGIS 10.1 with Python cookbook.
Step 6  says to type this : for row in sorted(cursor):
But if you look at the number 04 which gave the error because PyScripter could not defined cursor ?
I have also type this 04 code into Python window and it showed it doesn't defined cursor is ....
import arcpy.da arcpy.env.workspace ="c:/ArcpyBook/Ch9" arcpy.da.SearchCursor("Schools.shp",("Facility","Name"))    for row in in sorted(cursor):     print("School name: " + row[1])
DarrenWiens2
In any case, this is how I usually see and use da cursors:
>>> with arcpy.da.SearchCursor("YOUR_LAYER_HERE",("ID","FID")) as cursor:
...     for row in sorted(cursor):
...         print row
DarrenWiens2
You have two "in"s: "for row in in sorted(cursor):"
DarrenWiens2
...         print row
DEAF_PROBERT_68
Honored Contributor
Yes that worked !
RachelGomez
Let's check out some ways to fix this problem.
Double-Check Your Hardware.
Double-Check Your Mouse's Surface.
Change Touchpad Settings.
Disconnect Other Devices.
Run the Hardware Troubleshooter.
Update Your Mouse's Drivers.
Tame Your Mouse.
Regards,
Rachel Gomez
DEAF_PROBERT_68
Honored Contributor
Thank you however, this post was dated back in 2015. Hopefully others can test theirs.
JoshuaBixby
MVP Esteemed Contributor
@RachelGomez , the original question had to do with ArcPy cursors and not computer mouse cursors, so checking hardware and mouse and trackpad settings would have no effect.
