Error upload file
5802
7
02-15-2015 06:07 AM
roialgavish
I have published a geoprocessing tool that take a zip file, The zips are between 10 -100 MB.
When i try to upload from the my local network everything is working well.
When I try to upload from the internet (using flex), I am getting this errors:
Clients side (flex): "could not process upload complete response"
Server logs: "unable to process request. Error parsing multi-part request"
My server is 10.3
How can I make this work from the internet?
Thank you all,
Roi Algavish.
nicogis
Have you same result using http and https?
roialgavish
I am using http, do think i should try https?
thank you.
nicogis
Are you using web adaptor? if yes, what is written in 'site url'  in webadaptor.config?
roialgavish
in the siteurl:
http://xxx.x.x.xx:6080/
it us a domain acount
nicogis
Can you tried without web adaptor?
roialgavish
at the moment i am waiting for my internet provider to open the 6080 port, after they will open it.
i will try to bypass the web adaptor trough the 6080 port, and i will let you know if it worked.
thank you,
roi.
roialgavish
i just wanted to say that the bypass trough 6080 worked,
so the problem is either in the iis or in the web adaptor.
