Interpolating with IDW(geostatistical analyst): Python for Loop
5441
02-14-2015 05:42 PM
KevinAchieng
Hi All,
I'm trying to interpolate point feature classes with Python.  I would like the output to maintain the name of the input feature class.
However, my code seem not to be running.
Please assist me troubleshoot the code:
Thanks in advance.
Kevin
Please see below
# Import system modules
import arcpy
from arcpy import env
# Set environment settings
arcpy.env.workspace = r"\\bsedom5\users\kachieng2\Desktop\ET_2002-2014\Product\Monthly"
fclist=arcpy.ListFeatureClasses()
arcpy.env.overwriteOutput="True"
# Set local variables
inPointFeatures = "fc"
zField = "ETommd"
outLayer = "outIDW"
outRaster = r"\\bsedom5\users\kachieng2\Desktop\ET_2002-2014\Product\MonthlyET.gdb\fc"
cellSize = 2000.0
power = 2
# Set variables for search neighborhood
majSemiaxis = 300000
minSemiaxis = 300000
angle = 0
maxNeighbors = 15
minNeighbors = 10
sectorType = "ONE_SECTOR"
searchNeighbourhood = arcpy.SearchNeighborhoodStandard(majSemiaxis, minSemiaxis,
                                                       angle, maxNeighbors,
                                                       minNeighbors, sectorType)
# Check out the ArcGIS Geostatistical Analyst extension license
arcpy.CheckOutExtension("GeoStats")
# Execute IDW
for fc in fclist:
    outRaster = r"\\bsedom5\users\kachieng2\Desktop\ET_2002-2014\Product\MonthlyET.gdb\fc[:-4]"
    arcpy.IDW_ga(fc, zField, "", outRaster, cellSize, power, searchNeighbourhood)
DarrenWiens2
Also, your path to outRaster will not work as you expect. By leaving the variable fc[:-4] inside the quotes, it literally becomes part of the string (e.g. "...\Product\MonthlyET.gdb\fc[:-4]").
Instead, use the os module's path.join method to join your base path to the variable:
>>> fc = "someraster2014"
>>> import os
>>> outRaster = os.path.join(r"\\bsedom5\users\kachieng2\Desktop\ET_2002-2014\Product\MonthlyET.gdb",fc[:-4])
>>> print outRaster
\\bsedom5\users\kachieng2\Desktop\ET_2002-2014\Product\MonthlyET.gdb\someraster
DanPatterson_Retired
Which Place or Space is this to be directed?
You provide no error messages or what the problem is.  Since that is missing it is impossible to assist without going through the analysis ourselves.  What environment settings did you stipulate when performing the IDW other than those provided in the script?  Is the file paths some network location?  Have you tried source and destinations on a local drive etc.
DarrenWiens2
Off the top, it should be arcpy.env.overwriteOutput = True (no quotes) and setting inPointFeatures = "fc" literally sets the variable to the string "fc" and is never used.
DarrenWiens2
>>> import os
>>> print outRaster
KevinAchieng
Hi Darren,
I imported os, and used the join method. It worked!
Kevin
