Why are there duplicate records in the database?
4829
02-12-2015 01:13 PM
VenusScott
I added a couple of records using Collector then went back into one and updated the data a couple of times. In the Oracle database it shows a record multiple times? Is what I'm seeing the "xxx_H" records? Does a compress resolve the duplicate records? Just trying to understand from a database perspective of what I should be seeing when Collector updates records.
VenusScott
After more testing with Collector, I found that what I thought were duplicate records (based on OBJECTID) were actually the additional archived records as we have archiving enabled on this data. I'm so used to the OBJECTID being a unique primary key, this threw me off!
AlexMahrou
Are you accessing the base table or the versioned view? The versioned view will give you the best window into the data.
VenusScott
