How to keep the Editor widget (or any other widget) opened when application is loaded
4681
02-05-2015 04:34 AM
MiriEshel
Hi everybody,
I need to keep the Editor widget opened when application is opened.
As it looks now, the Edit widget is created upon clicking on the button.
I want it to be created in advanced and kept open from the beginning.
Is it possible? If yes, how?
Thanks a lot,
Miri
MiriEshel
Hi Robert,
Thanks a lot. I missed it out somehow.....
Thanks again,
miri
RobertScheitlin__GISP
Miri,
   If you are using the foldable theme then the process is simple you open the apps config.json and add the openAtStart property to the widgets you want preloaded.
Open a widget at app start—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
MiriEshel
Hi Robert,
Thanks again,
miri
Miri,
Glad to help. Now it is your turn to help the community by marking this question as answered. All you have to do is click the "Correct Answer" link (the one with the little green star) on the post that provided the answer for you.
In this thread and any others you have started If the answer was not provided by one of the responders then you can mark any of the replies that you received as helpful by clicking on the "Actions" menu and choosing "Mark as Helpful"
zhongrenGu
how to do with in the Tabable theme??  thanks,i think the Tabable theme is very good to use,hihi  thanks
