Hi all
I am using Esri Attribute Assistant toolbar version 10.2
When populating a field from an Expression in the DynamicValue table, how can use a retrieve the value from an intersection field?
field = "WWC-B" & [Municipality ID] & "-Meter"
I am creating a line and need to populate a feature with a string and the Municipality Code is stored in the Municipality Polygon intersected by the line.
Which method allows to do that?
