syntax to query a featureLayer using date field with Arcgis JS api?
5027
02-04-2015 07:48 AM
JohnSnow3
i have a featureLayer in my JS map, (snapshot_mode), I can make queries on the layer as below (so my issue is specifically how query the layer based on a date field e.g. show all features newer than 01/01/2014) -
 featurelayer.setDefinitionExpression("status = 0"); // for example this is working
I have looked through the documentation, however no success... I am unable to query the layer based on a date field,
I have tried both a static ("date_created > 2014-01-01") as well as passing in a js date variable - "new date(...) and a couple of others,
I also saw there is a setTimeDefinition, which I also attempted to use, but still an unsuccessful outcome,
so, any advice on how to filter by date will be very much appreciated,
thanks!
SteveCole
Honored Contributor
Dates values are in Epoch format so you'll need to specify your date value as such. If you have your date of interest as a variable, then the Epoch value of that date would be:
var epochDate = theDate.getTime() / 1000;
Your query then should be
"date_created > " + epochDate
This is untested, though..
