Editing - Auto populate custom fields
6009
5
02-04-2015 08:12 PM
RichardMoussopo
I am trying to auto populate the custom fields in the editor but no luck.
here is what I thought would work by assigning the value to the textBox but nothing...
var someValue = "My value";
var myTextBox = new dijit.form.TextBox({
        value: someValue
          var txtEmail = new dijit.form.TextBox({
        value: "my email here"
        var layerInfos = [{
          'featureLayer':featureLayer,
          'showAttachments':false,
          'showDeleteButton':true,
          'fieldInfos':[
            {'fieldName':'name','label':'Name','customField': myTextBox},
            {'fieldName':'email','label':'Email','customField': txtEmail}
KellyHutchins
Esri Notable Contributor
If you want to set default values for new features you can do this using the feature layer's before-apply-edits event.  If you set the default values there they will appear when the popup attribute window displays for new features.  Here's an example:
        requestLayer.on("before-apply-edits", function(g){
            var features = g.adds;
            for(i = 0; i < features.length; i++){
              var f = features;
              f.attributes.name = "Jane Doe";
RobertScheitlin__GISP
Richard,
   Have you tried to set the value after you create the textbox?
myTextBox.set('value', 'somevalue');
RichardMoussopo
Hi Robert,
yes I did try that still no luck. the image bellow shows the fields that need to be auto filled.
KellyHutchins
              var f = features;
RichardMoussopo
Thank you Kelly,
you saved my day !
LindaDunklee
I've been successful in modifying this code to update fields based on edited fields - however, when you change the driving field after the initial input, it does not update the dependent fields.  I believe this has something to do with the "before-apply-edits" but haven't been able to get anything else to work.  Kelly, do you have anything that would allow autopopulation that dynamically?
Thanks!
