How can i upload data on an ArcGIS featureServer using featureLayer.applyEdits
4661
01-30-2015 03:35 AM
StefanSchärer
I'm building out a hybrid App with ionic and angular-js, in which the user generates some data (geolocation, date, other...) which has to be uploaded into and expressed as a data point in an ArcGIS Webmap. Unfortunately, I'm quite a javascript beginner and I'm stuck.
That's the code I tried:
var featureLayerUrl = "LayerURL";
    var outFields = ["*"];
    require([
   "esri/layers/FeatureLayer",
   "esri/tasks/query",
   "esri/graphic",
   'dojo/_base/declare',
   "dgrid/OnDemandGrid",
   "dgrid/CellSelection",
   "dojo/store/Memory",
   "dojo/_base/array",
   "esri/tasks/query", "esri/tasks/QueryTask",
   "dojo/dom",
   "dojo/on",
   "dojo/dom-style",
   "dojo/domReady!",
    "esri/geometry/Point",
        "esri/geometry/Geometry",
        "esri/symbols/Symbol",
        "esri/symbols/SimpleMarkerSymbol"
  ], function (FeatureLayer, Query, Graphic, Geometry, Point, SpatialReference,
        declare, OnDemandGrid, CellSelection, Memory, arrayUtils, Query, QueryTask, dom, on, domStyle, SimpleMarkerSymbol, Symbol) {
        var featureLayer = new FeatureLayer(featureLayerUrl, {
            outFields: outFields
$scope.addFeatureNow = function () {
            // TODO: Adapt with all the attributes
           //Defines Symbols
            var symbol;
            if (allgDatenService.BioWaterQuality = "unpolluted - I") {
                symbol = new SimpleMarkerSymbol({
                    "color": [0, 92, 230, 255],
                    "size": 6,
                    "angle": 0,
                    "xoffset": 0,
                    "yoffset": 0,
                    "type": "esriSMS",
                    "style": "esriSMSDiamond",
                    "outline": {
                        "color": [255, 255, 255, 255],
                        "width": 1
            }else if (allgDatenService.BioWaterQuality = "slightly polluted - I-II") {
                    "color": [0, 197, 255, 255],
                    "size": 6,
                    "angle": 0,
                    "xoffset": 0,
                    "yoffset": 0,
                    "type": "esriSMS",
                    "outline": {
                        "width": 1
            } else if (allgDatenService.BioWaterQuality = "moderately polluted - II") {
                    "color": [85, 255, 0, 255],
                    "size": 6,
                    "angle": 0,
                    "xoffset": 0,
                    "yoffset": 0,
                    "type": "esriSMS",
                    "outline": {
                        "width": 1
            } else if (allgDatenService.BioWaterQuality = "seriously polluted - II-III") {
                    "color": [255, 170, 0, 255],
                    "size": 6,
                    "angle": 0,
                    "xoffset": 0,
                    "yoffset": 0,
                    "type": "esriSMS",
                    "outline": {
                        "width": 1
            } else if (allgDatenService.BioWaterQuality = "heavily polluted - III") {
                    "size": 6,
                    "angle": 0,
                    "xoffset": 0,
                    "yoffset": 0,
                    "type": "esriSMS",
                    "outline": {
                        "width": 1
            } else if (allgDatenService.BioWaterQuality = "very heavily polluted - III-IV") {
                    "color": [255, 85, 0, 255],
                    "size": 6,
                    "angle": 0,
                    "xoffset": 0,
                    "yoffset": 0,
                    "type": "esriSMS",
                    "outline": {
                        "width": 1
            } else if (allgDatenService.BioWaterQuality = "excessively polluted - IV") {
                    "color": [168, 56, 0, 255],
                    "size": 6,
                    "angle": 0,
                    "xoffset": 0,
                    "yoffset": 0,
                    "type": "esriSMS",
                    "outline": {
                        "width": 1
            var geometry = new Point(allgDatenService.long, allgDatenService.lat, new SpatialReference({
                wkid: 4326
            var attributes = {
                "rivername": allgDatenService.rivername,
                "organisation": allgDatenService.organisation,
                "comments": allgDatenService.comments,
                "BioWaterQuality": allgDatenService.BioWaterQuality,
                "landscape_eco_number": allgDatenService.landscape_eco_number,
                "LandscapeEcology": allgDatenService.LandscapeEcology,
                "CreationDate": allgDatenService.CreationDate,
                "Creator": "SomeCreator"
            var graphic = new Graphic(geometry, symbol, attributes, null);
            featureLayer.applyEdits(graphic, null, null, function () {
                $log.log("addFeatureSuccess");
            }, function () {
                alert("An error occured during add.");
So, somehow the console gives me a "addFeatureSuccess", the featureLayer.applyEdits() is executed, but...
When I go and check if there's a data-point in my Map, there isn't. What did I do wrong?
Thanks for any help provided...
KenBuja
MVP Esteemed Contributor
The first thing that jumps out is your function arguments do not match your require modules. They are out of order and missing some modules. This is a must! Read this blog for more information.
require([
   "esri/tasks/query",
   "esri/graphic",
   "esri/SpatialReference",
   "dojo/_base/declare",
   "dojo/_base/array",
   "dojo/dom",
   "dojo/on",
   "dojo/dom-style",
   "esri/symbols/SimpleMarkerSymbol",
   "dojo/domReady!"
        declare, OnDemandGrid, CellSelection, Memory, arrayUtils, QueryTask, dom, on, domStyle, SimpleMarkerSymbol, Symbol) {
