Change Spatial Reference
3857
01-29-2015 01:21 PM
mpboyle
Honored Contributor
We have certain datasets that have a XY resolution that makes no sense: 0.000053551048115 ft.  We are trying to migrate our data to a new database which has default settings for the XY resolution and tolerance, which is: 0.000328083333333 ft.
Using the Upgrade Spatial Reference tool doesn't work because our existing XY resolution is more precise than the default.  Is there a way to change/alter an existing spatial reference to a lower precision?
Thanks in advance!
Tags (1)
MelitaKennedy
Esri Notable Contributor
Because the xy resolution value affects data storage, you would have to reload. Sorry!
mpboyle
Honored Contributor
Melita Kennedy‌ - how would I handle feature classes that use attachments then...?
