display xy points at correct location
5909
10
01-28-2015 09:44 AM
panlu
I have the data downloaded on-line and have no idea about the original coordinate system. I observed the x and y values, they looks like in meters,
The latitude is something like: 468769600, and longitude like: -1028108400. the points should located in ND, and I tried UTM14N and WGS1984 none of them works. Any help would be appreciated. Many thanks
MelitaKennedy
Esri Notable Contributor
Weirdly enough, these might be scaled latitude and longitude.
Original:
latitude: 468769600
longitude: -1028108400
If I divide by 10000000,
latitude: 46.8769600
longitude: -102.8108400
which certainly fits North Dakota.
JoeBorgione
Just a guess:  check for a ND state plane coordinate system....
panlu
tried but still not work. There are several outliers (with 0 Lat/Lon values) I don't know if those can cause trouble
XanderBakker
Esri Esteemed Contributor
I think you an issue with the decimal sign of the coordinates. If your x-coord (longitude) is expressed in meters, it would be like 25-26 times the circumference of the world. That doesn't make sense.
panlu
Yes, you are right. the values in my table looks like in a unit of cm. What coordinate system would generate CM values?
DarrenWiens2
I don't think you can determine the unit by the magnitude of the coordinates. They are just numbers - you could make a custom coordinate system with the origin 1,000,000 times the circumference of the Earth away from your data. How did you decide that your unit is cm, other than they are large numbers?
Where did you download this data from? There was surely metadata.
MelitaKennedy
Original:
latitude: 468769600
panlu
Yes, you are life saver. After I divide by 10000000, they are mapped at correct locations. Thanks a lot!!
XanderBakker
pan lu‌, could you mark the thread as answered? In the lower left corner of Melita's post, there should be a button "Correct Answer".
panlu
Thanks, I could not see the button earlier. Done now.
